Full Version: VC1 1080p only 15 frames
Pages: 1 2
Hi ,
this is my first post :-)
I did now play since days with the xbmc and i dont get it to work well.
i had some problems to get my xbmc 9.11 Camelot setup to run.
I did only get 15 frames on my Asrock ION 330HT with the NVIDA PPA Driver 195 and VPAU.
i did use this script to setup my system http://forum.xbmc.org/showthread.php?tid=55282&page=18 (Version in Post 176)
CPU Load is 140% during playback.
And it makes no sense if i change the Render Method in xbmc.
What is wrong here ...?
Cu
Dirk
Debug log
Hi again ,
sorry ...
here comes the log ..
http://files.me.com/ahrensfd/18x8zr
Hope the "Gang" can help me :-)
I did see that in the log ..
14:33:51 T:2591001456 M:1435312128 DEBUG: Loading: /usr/share/xbmc/system/players/dvdplayer/swscale-0.6.1-i486-linux.so
14:33:51 T:2591001456 M:1434669056 NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1920x1080)
14:33:51 T:2591001456 M:1434669056 NOTICE: (VDPAU) unable to get handle to libvdpau
14:33:51 T:2591001456 M:1434537984 NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
14:33:51 T:2591001456 M:1434669056 NOTICE: (VDPAU) ~CVDPAU
14:33:51 T:2591001456 M:1434669056 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: SMPTE VC-1
14:33:51 T:2591001456 M:1433141248 DEBUG: FactoryCodec - Video: ff-vc1 - Opened
14:33:51 T:2591001456 M:1433141248 NOTICE: Creating video thread
14:33:51 T:2591001456 M:1433141248 NOTICE: Opening audio stream: 1 source: 256
14:33:51 T:2580511600 M:1433141248 DEBUG: thread start, auto delete: 0
14:33:51 T:2591001456 M:1433141248 NOTICE: Finding audio codec for: 86020
14:33:51 T:2580511600 M:1433141248 DEBUG: LinuxRendererGL: Cleaning up GL resources
14:33:51 T:2591001456 M:1433141248 DEBUG: FactoryCodec - Audio: passthrough - Opening
14:33:51 T:2580511600 M:1433141248 NOTICE: running thread: video_thread
14:33:51 T:2591001456 M:1433141248 DEBUG: FactoryCodec - Audio: passthrough - Failed
14:33:51 T:2591001456 M:1433141248 DEBUG: FactoryCodec - Audio: liba52 - Opening
14:33:51 T:2591001456 M:1433141248 DEBUG: Loading: /usr/share/xbmc/system/players/dvdplayer/liba52-i486-linux.so
14:33:51 T:2591001456 M:1433292800 DEBUG: FactoryCodec - Audio: liba52 - Opened
14:33:51 T:2591001456 M:1433292800 NOTICE: Creating audio thread
14:33:51 T:2570021744 M:1433292800 DEBUG: thread start, auto delete: 0
14:33:51 T:2570021744 M:1433292800 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
14:33:51 T:2611981168 M:1433292800 DEBUG: Process, request seek on source to 28329645124
14:33:51 T:2611981168 M:1433460736 INFO: CFileCache:Tonguerocess - Hit eof.
cu
Dirk
seems like ffmpeg has severe issues with the stream. are they interlaced by any chance?
ahem... did you install libvdpau? it seems you didn't
succo ..
How i do that ?
I did that ..
##--[ INSTALL GENERIC NVIDIA GRAPHIC DRIVERS ]---------------------------------------------------------------
apt-get install linux-headers-generic nvidia-glx-195 -y
cu
Dirk
Some one can help me ?
sudo apt-get install nvidia-libvdpau-195-dev or thereabout.
if you don't need ubuntu with all applications, I'd still recommend going the live install route
with minor settings it works out-of-the-box on ION systems
ahrensfd Wrote:succo ..
How i do that ?
I did that ..
cu
Dirk
in recent distros you can't sudo apt-get install nvidia-libvdpau-195-dev
i guess you need to sudo apt-get install libvdpau libvdpau-dev (maybe libvdpau1, i can't remember) as libvdpau has gone standalone
apt-cache search vdpau Wink
Hi ,
did give me an error -> Can´t find paket nvidia-libvdpau-195
did work for me ! I get this in my terminal window
xbmc@xbmc:~$ sudo apt-get install nvidia-libvdpau
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut
Lese Status-Informationen ein... Fertig
Hinweis: wähle nvidia-185-libvdpau an Stelle von nvidia-libvdpau
Die folgenden NEUEN Pakete werden installiert:
nvidia-185-libvdpau
0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 764kB an Archiven heruntergeladen werden.
Nach dieser Operation werden 1.565kB Plattenplatz zusätzlich benutzt.
Hole:1 http://de.archive.ubuntu.com karmic/restricted nvidia-185-libvdpau 185.18.36-0ubuntu9 [764kB]
Es wurden 764kB in 4s geholt (170kB/s)
Wähle vormals abgewähltes Paket nvidia-185-libvdpau.
(Lese Datenbank ... 54944 Dateien und Verzeichnisse sind derzeit installiert.)
Entpacke nvidia-185-libvdpau (aus .../nvidia-185-libvdpau_185.18.36-0ubuntu9_i386.deb) ...
Richte nvidia-185-libvdpau ein (185.18.36-0ubuntu9) ...
Verarbeite Trigger für libc-bin ...
ldconfig deferred processing now taking place
Sorry it´s a german linux :-)
Now it works !
How can i check if it the version 0.3-2 of libvdpau ?
cu
Dirk
anyway, it's just sudo apt-get install libvdpau, if you have nvidia-vdpau ppa setup
nvidia-185-libvdpau, i think, are from standard ubuntu repositories and are quite old
Hi succo ,
as u can see i did sudo apt-get install nvidia-libvdpau
but i got a notification that nvidia-185-libvdpau was selected in instead of nvidia-libvdpau.
Downloaded from http://de.archive.ubuntu.com[/url] karmic/restricted nvidia-185-libvdpau 185.18.36-0ubuntu9
Dont know why ?
I did set add-apt-repository ppa:nvidia-vdpau/ppa and did download the NVIDIA Driver via apt-get install linux-headers-generic nvidia-glx-195 -y
this works well but not the sudo apt-get install nvidia-libvdpau command. It give the log below
nvidia-185-libvdpau
succo Wrote:anyway, it's just sudo apt-get install libvdpau, if you have nvidia-vdpau ppa setup
Here is what worked for me:
I first removed all nvidia drivers with:
sudo apt-get autoremove nvidia-glx*
Then installed the 195-30 drivers:
sudo apt-get install nvidia-glx-195
Finally, installed the correct version of libvdpau (thanks succo!):
sudo apt-get install libvdpau1 libvdpau-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Suggested packages:
  libvdpau-doc nvidia-vdpau-driver vdpau-driver
The following packages will be REMOVED:
  nvidia-185-libvdpau
The following NEW packages will be installed:
  libvdpau-dev libvdpau1
0 upgraded, 2 newly installed, 1 to remove and 4 not upgraded.
Need to get 65.3kB of archives.
After this operation, 1,200kB disk space will be freed.
Do you want to continue [Y/n]? y
Get:1 http://ppa.launchpad.net karmic/main libvdpau1 0.3-2~nvidiavdpauppa5 [23.9kB]
Get:2 http://ppa.launchpad.net karmic/main libvdpau-dev 0.3-2~nvidiavdpauppa5 [41.3kB]
Fetched 65.3kB in 1s (36.7kB/s)
(Reading database ... 48574 files and directories currently installed.)
Removing nvidia-185-libvdpau ...
Processing triggers for libc-bin ...
Selecting previously deselected package libvdpau1.
(Reading database ... 48564 files and directories currently installed.)
Unpacking libvdpau1 (from .../libvdpau1_0.3-2~nvidiavdpauppa5_i386.deb) ...
Selecting previously deselected package libvdpau-dev.
Unpacking libvdpau-dev (from .../libvdpau-dev_0.3-2~nvidiavdpauppa5_all.deb) ...
Setting up libvdpau1 (0.3-2~nvidiavdpauppa5) ...
Setting up libvdpau-dev (0.3-2~nvidiavdpauppa5) ...
Testing now to see if stuttering has been corrected.
Pages: 1 2
