2010-01-04, 21:16
This is a brief description how to set up a dedicated HTPC with the latest XBMC, but using Ubuntu 8.04 (Hardy) as underlying OS.
Tech note: why would one want not the latest 9.11 (Karmic), but an year-and-a-half-old release? Surely, Karmic boots faster and loads X faster; however, some hardware doesn't not like recent kernels. A prominent example are NVdidia motherboards with IDE disk drives, which are not stable with libata - with older versions of Ubuntu kernel where everything which could be a module was compiled as a module, it was not hard to drop the troublesome pata_amd modules and use amd74xx; however, since recent verisons Ubuntu builds libata into the kernel thus requiring a full kernel recompile, followed by manual NVidia video drivers install - a truly daunting task. In such cases, it is easier to use the good old 8.04, which is LTS and therefore many recent enhancements are available for it also. The slightly slower boot should not be a too big trade-off.
First, get the Ubuntu 8.04 minimal CD. It has the advantage that everything will be installed from the Internet, thus providing you directly with the latest versions of all system software (saving a lot of time to upgrade):
Burn the disk and carry an installation. You should use "xbmc" as a username for XBMC. When asked what additional software to install, chose OpenSSH server. Complete the installation. Reboot, then log in remotely over SSH - this way you'll be able to copy/paste all commands, listed below.
Become a superuser - when asked, give again the password for user "xbmc":
Add required repositories. I assume you are comfortable with vim as an editor - if not, replace it here and below with "nano":
At the end of the file, copy these lines:
Obtain required keys:
Get a list of all packages, available in the repositories:
There are few pieces of software which we shall need, but which are not listed as dependencies - therefore, we need to install them explicitly:
Grant required privileges to user "xbmc":
Also, do a required change in dbus config file in order to shut down the HTPC from XBMC:
In the last section, just before the line "</busconfig>" add these lines:
A small addition to Policy Kit configuration
edit the line "<match user=..." and add "|xbmc" after "root":
A small addition to power management:
on lines stating with "<allow_active..." replace "auth_admin" with "yes" so it looks like t his:
Add "vfat" to the list of filesystems which should be automounted from USB drives:
Next to ext2 and ext3 on the line, beginning with "FILESYSTEMS=..." add "vfat":
Get the X server and the latest stable proprietary drivers:
Let NVidia driver generate a proper config file, you may tweak it later to your taste:
Install audio subsystem:
Run the console mixer. Set the desired sliders, the press "Esc" to exit. Run the second command to save current settings:
Get the XBMC itself:
Set up auto-login:
Replace the last line (starting with "exec...") with this one:
Create a file to auto-run X upon login:
Put inside these lines:
Finally, when X comes up, let if fire XBMC:
Put inside this line:
Install a fancy graphical boot:
Set your resolution:
For 720p TV, put these lines (for 1080p, make the numbers 1920 and 1080 respectively)
Update the initial RAM disk with the graphical boot
If you want to have CDs automatially mounted (needed only if you play MP3s or ripped DVDs off CD-R/DVD-Rs and want better control over them):
You can then create mount point for the CD/DVD and a map file. Because the automounter takes over the mounting point, do not use "/media", but rather create a new directory "/media/automounter". In /home/xbmc create a symlink to /media/automounter/cdrom:
Create a map file "/etc/auto.media" (you may want to add UDF) and link it in "/etc/auto.master"
Put inside this line (assuming /dev/scd0 is your CD/DVD drive; if not, put proper device):
Finally, link this new file to the master file:
Put this line inside:
If you use a remote control, install LIRC, then configure it up to your taste (setting up LIRC is outside our scope here):
If you use NFS (as I do sometimes), install the client part of it:
If you want to use MIDI-based karaoke (.KAR files), you'll need to install a soundfont:
Well, that's it. Reboot and enjoy :-)
WWell,
https://help.ubuntu.com/community/Installation/MinimalCD
sudo bash
vim /etc/apt/sources.list
deb http://archive.ubuntu.com/ubuntu hardy-backports main universe multiverse restricted
deb-src http://archive.ubuntu.com/ubuntu hardy-backports main universe multiverse restricted
deb http://ppa.launchpad.net/nvidia-vdpau/ppa/ubuntu hardy main
deb-src http://ppa.launchpad.net/nvidia-vdpau/ppa/ubuntu hardy main
deb http://ppa.launchpad.net/team-xbmc/ppa/ubuntu hardy main
deb-src http://ppa.launchpad.net/team-xbmc/ppa/ubuntu hardy main
apt-key adv --keyserver keyserver.ubuntu.com --recv-keys CEC06767 91E7EE5E
apt-get update
apt-get install hal usbmount pkg-config policykit
polkit-auth --user xbmc --grant org.freedesktop.hal.power-management.suspend
polkit-auth --user xbmc --grant org.freedesktop.hal.power-management.hibernate
polkit-auth --user xbmc --grant org.freedesktop.hal.power-management.reboot
polkit-auth --user xbmc --grant org.freedesktop.hal.power-management.shutdown
polkit-auth --user xbmc --grant org.freedesktop.hal.power-management.reboot-multiple-sessions
polkit-auth --user xbmc --grant org.freedesktop.hal.power-management.shutdown-multiple-sessions
vim /etc/dbus-1/system.d/hal.conf
<policy user="xbmc">
<allow send_interface="org.freedesktop.Hal.Device.SystemPowerManagement"/>
<allow send_interface="org.freedesktop.Hal.Device.VideoAdapterPM"/>
<allow send_interface="org.freedesktop.Hal.Device.LaptopPanel"/>
<allow send_interface="org.freedesktop.Hal.Device.Volume"/>
<allow send_interface="org.freedesktop.Hal.Device.Volume.Crypto"/>
</policy>
vim /etc/PolicyKit/PolicyKit.conf
<match user="root|xbmc">
vim /usr/share/PolicyKit/policy/org.freedesktop.hal.power-management.policy
<allow_active>yes</allow_active>
vim /etc/usbmount/usbmount.conf
FILESYSTEMS="ext2 ext3 vfat"
apt-get install xorg
apt-get install nvidia-190-modaliases nvidia-glx-190 nvidia-settings-190
nvidia-xconfig
apt-get install linux-sound-base alsa-base alsa-utils
alsamixer
alsactl store 0
apt-get install xbmc xbmc-skin-* xbmc-eventclients-* xbmc-scripts-*
Set up auto-login:
vim /etc/event.d/tty1
exec /bin/login -f xbmc < /dev/tty1 > /dev/tty1 2>&1
vim /home/xbmc/.bash_profile
case "`tty`" in
/dev/tty1) clear && startx &>/dev/null;;
esac
vim /home/xbmc/.xsessionrc
exec xbmc --standalone
sudo apt-get install usplash libusplash-dev usplash-theme-xbmc-*
sudo update-alternatives --config usplash-artwork.so
vim /etc/usplash.conf
resx=1280
resy=720
update-initramfs -u
apt-get install autofs
mkdir /media/automounter
ln -s /media/automounter/cdrom0 /home/xbmc/cdrom
vim /etc/auto.media
cdrom0 -fstype=iso9660,ro,nosuid,nodev :/dev/scd0
vim /etc/auto.master
/media/automounter /etc/auto.media
apt-get install lirc
apt-get install nfs-common
apt-get install fluid-soundfont-gm fluid-soundfont-gs
mkdir /usr/share/xbmc/system/players/paplayer/timidity
cd /usr/share/xbmc/system/players/paplayer/timidity
ln -s /usr/share/sounds/sf2/FluidR3_GM.sf2 soundfont.sf2
WWell,
