Full Version: Previous button returns me to source and add source
I'm running the latest git of Alaska, and I'm wondering how I can change some behaviour in it.
I don't run a library for my music and when I select the previous button on my remote (apple remote) in what I'd call the root dir for my music (which lists all of the artists) it takes me to the sources screen which has my Music source and the "add source" function. How can I have it take me straight back out to the main menu?
cheers,
Jason.
Map the ESC key to your remote.
should have mentioned i'm running linux on the appletv... don't believe I can map an esc code to the remote Sad
ewequeone Wrote:should have mentioned i'm running linux on the appletv... don't believe I can map an esc code to the remote Sad
if you are using lirc you should be able to map a button to activatewindow(home) instead of esc
more info here : http://wiki.xbmc.org/?title=Window_IDs
