2010-01-05, 20:24
Unfortunately I can't upload a crash / fault log as XBMC doesn't know there's a problem.
Running Camelot 9.11 Final Release on Windows XP 32 Bit SP3 with digital audio over HDMI.
After the system has been left on for a few days when I go to play any video file over XBMC the audio is out of sync, the longer the system is left between reboots the further out of sync it is.
This was never a problem on XBMC 9.04 and can only been solved by a reboot (very strange that killing XBMC and restarting it doesn't fix the issue).
I can post a complete hardware list including chipsets if required, I would suspect it was a windows issue but no new drivers or updates have been installed...
