2010-01-06, 00:49
I cannot play a retail DVD disk in xbmc. I have automatic detection on. When a DVD in inserted I can also see the DVD in Video files but when I click it to play it says "No disk present". When I try to play it using the play button in the home screen with the Confluence skin, it also gives me a "no disk present, insert disk".
I've tried switching the region code to 2 (europe) but it all doesn't help.
Iso files run fine by the way. Also the ones with a menu.
I'm running version 9.11 Camelot on Windows 7 64bit on a Gigabyte GA-MA78GM-S2H780FX with an AMD ATHLON 64 X2 4850E. I use the onboard videocard with 512 MB allocated. 4 GB of DDR2 installed.
debug log is:
http://pastebin.com/f917aebc
debug log is:
