No. I can load the file but once I start the conversion, it stops directly... without actually doing something.
### Windows GUI 0.9.4 2009112300
### Running: Microsoft Windows NT 6.1.7600.0
### CPU: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
### Ram: 3582 MB
### Screen: 1920x1200
### Temp Dir: C:\Users\Administrator\AppData\Local\Temp\2\
### Install Dir: C:\Program Files (x86)\HandBrake
### Data Dir: C:\Users\Administrator\AppData\Roaming\HandBrake\HandBrake\0.9.4.0
[16:54:00] hb_init: checking cpu count
[16:54:01] hb_init: starting libhb thread
HandBrake 0.9.4 (2009112300) - MinGW i386 - http://handbrake.fr
2 CPUs detected
Opening L:\Series\Dark Blue\Season 1\Dark.Blue.S01E01.WMV...
[16:54:01] hb_scan: path=L:\Series\Dark Blue\Season 1\Dark.Blue.S01E01.WMV, title_index=0
[16:54:01] scan: trying to open with libdvdread
libdvdnav: Using dvdnav version 4.1.3
libdvdread: Encrypted DVD support unavailable.
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
libdvdread: Can't open file VIDEO_TS.IFO.
libdvdnav: vm: failed to read VIDEO_TS.IFO
[16:54:01] dvd: not a dvd - trying as a stream/file instead
Input #0, asf, from 'L:\Series\Dark Blue\Season 1\Dark.Blue.S01E01.WMV':
Duration: 00:45:05.54, start: 3.000000, bitrate: 3319 kb/s
Stream #0.0(dut): Audio: 0x0162, 48000 Hz, 5.1, s16, 440 kb/s
Stream #0.1(dut): Video: vc1, yuv420p, 1280x720, 2870 kb/s, PAR 1:1 DAR 16:9, 24 tbr, 1k tbn, 1k tbc
[16:54:01] scan: decoding previews for title 1
Scanning title 1 of 1...
[16:54:02] scan: 10 previews, 1280x720, 24.000 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1
[16:54:02] scan: title (0) job->width:1280, job->height:720
[16:54:02] libhb: scan thread found 1 valid title(s)
+ title 1:
+ vts 0, ttn 0, cells 0->0 (0 blocks)
+ angle(s) 0
+ duration: 00:45:05
+ size: 1280x720, pixel aspect: 1/1, display aspect: 1.78, 24.000 fps
+ autocrop: 0/0/0/0
+ chapters:
+ 1: cells 0->0, 0 blocks, duration 00:45:05
+ audio tracks:
+ subtitle tracks:
HandBrake has exited.
############ End of Log ##############
