Have been trying to fix this problem for a while, but can't figure it out. Hope someone can help.
I'm running Camelot on Ubuntu Karmic Minimal on an ION 330.
System language is set to english. When I add a new episode to a tvshow, XBMC does not find it. The DEBUG log shows that it apparently does get the language, as the system tries to load
http://www.thetvdb.com/api/1D62F2F90030C...1/all/.zip, which doesn't exist, it should be (...)/all/en.zip
Relevant part of my log is here
http://pastebin.com/m4dd50b9a
Regards,
Erik
You set content while tvdb was down. Check the scraper settings again, select the wanted language and give it another try.
Thanks for the reply! I tried, but the problem remains (log errors are similar to the ones above). However, when i completely reload the tvshow in the library, it finds the new episode, while it doesn't when i scan for new episodes. Strange, but the workaround at least keeps me going.
I went on to find a solution for this problem, because te problem remains for all my shows, even after clearing the complete DB and doing a complete rescan. Reloading the complete show finds the new episode, scanning for new content doesn't. Log is similar to the one posted above. I tried editing the scraper, but it didn't work out, probably due to inexperience on my side. Imho this is a problem that needs some attention from a developer. For now, I found a workaround that enables scanning for new content. The solution is not elegant, but it works. Maybe it will help others.
First, luckily,
http://www.thetvdb.com also works when approached using its ip, 67.152.32.114, so I was able to rewrite the url on my local machine.
Im am also running apache and mode_rewrite on my ION330, so I started rerouting traffic to tvdb to my local machine by adding this line to /etc/hosts
127.0.0.1 www.thetvdb.com www.thetvdb.com
Then I configured a VirtualHost in apache for
http://www.thetvdb.com. (see google for a manual)
Second, in the webroot of the virtual host, I created an htaccess.
Options +FollowSymLinks
RewriteBase /
RewriteEngine On
RewriteRule ^api\/([A-Za-z0-9_-]+)\/series\/([0-9]+)/all/en.zip http://67.152.32.114/api/$1/series/$2/all/en.zip [R=301,L]
RewriteRule ^api\/([A-Za-z0-9_-]+)\/series\/([0-9]+)/all/.zip http://67.152.32.114/api/$1/series/$2/all/en.zip [R=301,L]
RewriteRule ^(.*)$ http://67.152.32.114/$1 [R=301,L]
This does a small rewrite for the url, so the unfunctional request to
results in a redirect to
http://67.152.32.114/api/1D62F2F90030C44...all/en.zip
Cheers and keep up alle the good work on XBMC!
