2010-01-07, 20:05
KVCD is not my usual format, but I just found a few on an old computer. I used to use them since they would play back nicely in my Phillips DVD player and in the car.
Anyway, I checked and xbmc says it shold be able to play vcd's and the bin/cue format is readable. These files mount up ok with deamon tools and I can play the dat mpeg in them. But XBMC just plays a horrible noise and the screen never jumps to the player, it just sits at the menu screeching.
Pastebin says my file is too big, almost 2 mb..
but here is the probably pertinent info:
the Invalid parameters 0 0 0 error is about 5% of my log, the Unknown sector type 20/60 about 1% the Invalid parameters ## ##### -####### is about 80%
22:28:39 T:5704 M:1200406528 NOTICE: DVDPlayer: Opening: smb://SHERAH/SharedDocs/My Videos/Indiana Jones and the Raiders of the Lost Ark (1981).bin
22:28:39 T:5704 M:1200406528 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:28:39 T:4420 M:1200406528 DEBUG: thread start, auto delete: 1
22:28:39 T:4108 M:1200336896 DEBUG: thread start, auto delete: 0
22:28:39 T:4108 M:1200267264 NOTICE: Creating InputStream
22:28:39 T:4108 M:1199071232 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles
22:28:39 T:4108 M:1199071232 DEBUG: CUtil::CacheSubtitles: START
22:28:39 T:4108 M:1199071232 DEBUG: CUtil::CacheSubtitles: Checking for common subirs...
22:28:39 T:4108 M:1199071232 DEBUG: CUtil::CacheSubtitles: Done (time: 19 ms)
22:28:39 T:4108 M:1199071232 DEBUG: CUtil::CacheSubtitles: Searching for subtitles...
22:28:39 T:4108 M:1199071232 DEBUG: CUtil::CacheSubtitles: Done (time: 5 ms)
22:28:39 T:4108 M:1199071232 DEBUG: CUtil::CacheSubtitles: END (total time: 24 ms)
22:28:39 T:4108 M:1199071232 INFO: CDVDFactorySubtitle::GetSubtitles, searching subtitles done
22:28:39 T:4108 M:1199071232 NOTICE: Creating Demuxer
22:28:39 T:4108 M:1199071232 DEBUG: CDVDDemuxFFmpeg::Open - probing detected format [psxstr]
22:28:39 T:4108 M:1199071232 DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info starting
22:28:39 T:4108 M:1199071232 ERROR: ffmpeg[100C]: [psxstr] Invalid parameters 0 0 0
22:28:39 T:4108 M:1197883392 DEBUG: ffmpeg[100C]: [psxstr] Unknown sector type 20
22:28:39 T:4108 M:1197355008 DEBUG: ffmpeg[100C]: [psxstr] Unknown sector type 60
22:28:39 T:4108 M:1197355008 ERROR: ffmpeg[100C]: [psxstr] Invalid parameters 33 11777 -536805376
