2010-01-08, 11:26
Hallo,
I have built xbmc 9.11 from source and have now a problem with Lircmap.xml.
In the original /usr/local/share/xbmc/system/Lircmap.xml is defined a device iMON-PAD by default:
My lircd.conf looks like this:
I have created /root/.xbmc/userdata/Lircmap.xml to represent the codes from my lircd.conf
But this has no effect. The keys left, right, up, down on my remote do not work.
Other keys, where the codes in the default Lircmap and my lircd.conf are the same, are working properly.
When I make the changes directly in /usr/local/share/xbmc/system/Lircmap.xml the keys are o.k..
It seems that my userdata/Lircmap.xml has no effect.
In the log both Lircmap files are mentioned
/root/.xbmc/temp/xbmc.log:
Any ideas why the Lircmap.xml in my user directory has no effect?
goldbär
<remote device="iMON-PAD">
<left>Left</left>
<right>Right</right>
<up>Up</up>
<down>Down</down>
</remote>
begin remote
name iMON-PAD
begin codes
Mouse_N 0x01008000
Mouse_S 0x01007F00
Mouse_W 0x01000080
Mouse_E 0x0100007F
<left>Mouse_W</left>
<right>Mouse_E</right>
<up>Mouse_N</up>
<down>Mouse_S</down>
</remote>
04:42:37 T:3042166672 M:1853714432 NOTICE: special://masterprofile/ is mapped to: /root/.xbmc/userdata
04:42:37 T:3042166672 M:1853714432 NOTICE: special://home/ is mapped to: /root/.xbmc
04:42:37 T:3042166672 M:1853116416 NOTICE: special://profile/ is mapped to: special://masterprofile/
04:42:37 T:3042166672 M:1846288384 INFO: Loading special://xbmc/system/Lircmap.xml
04:42:37 T:3042166672 M:1846288384 INFO: Loading special://profile/Lircmap.xml
goldbär
