I have Asrock ION 330-HT. When i connect USB stick i would like to transfer all movie files to my movies folder on my local HDD (using remote control only). It there any script or program availible to do this?
With the default, "confluence" skin. On home screen, navigate to system, the press right. Pick "file manager." You ought to be able to take it from here.
on the confluence skin, is there any way in file manager to copy folders (containing files) without having to use the mouse?
The problem is that you have to right click on the folder and select copy. Without a mouse, when you select rightclick on a folder (using whatever mapping you have for right-click on your chosen device) it simply backs you out to the main menu instead of bringing up the context menu.
Is there a trick to doing this when not using a mouse?
I never use the mouse in xbmc. Press 'c', there's probably some way to queue up shit too. It's '1' on a remote, dunno about keyboard.
