Full Version: Library Management Pro (Linux Script)
Very useful script for those that like the library view of XBMC. This script will return orphan files in database and or filesystem along with other useful information to help you.
Setup is quick and easy and should work cross platform but I can confirm functionality for linux.
Please read the script to save me excessive typing all help and info are located inside. Let me know what you think updates that need done etc. I plan on creating a wiki for this soon.
#!/usr/bin/env python
### Description   ###
# This script is intended for people using XBMC library function.
# There are two modes to this script to assist you in organizing your library.
#     1)  Checks all files located in specified location.  Then returns message
#        if this file does not exist in database.
#    2)  Checks each record in the database then looks to see if the file exists.
# Output could come in the following forms:
#    1) ORPHANFS ENTRY FOUND: /home/soukenka/tvshows/CSI/Season 10/CSI.S10E02.720p.HDTV.X264-DIMENSION.mkv
#    This means that there was a file located in the filesystem that was not found in the database.  This could
#    be resolved by a simple update library.  However if the file is still displayed in output with an up to date
#    library then you need to resolve whatever naming issue you are experiencing.  Many articles exists to assist
#    you in getting this into your library for example: http://wiki.xbmc.org/?title=TV_Shows
#    2) ORPHANDB ENTRY FOUND: /home/soukenka/downloads/torrents/tvshows/Medium/Season 4/Medium_S04E01.avi
#    This means that you probly deleted the file however it still exists in the library.  Running a clean library
#    from the settings menu usually resolves this.
#    3) RAR ENTRY FOUND: /home/soukenka/movies/Open.Graves.2009.DVDRip.XViD-ReenCoTRiN/rar://%2fhome%2fasoukenka%2fmovies%2fOpen%2eGraves%2e2009%2eDVDRip%2eXViD%2dReenCoTRiN%2freencitrin%2dgravecitrin%2erar/reencitrin-gravecitrin.avi
#    Was not sure how to put this problem exists that because it is a rar file there are usually several parts which cause
#    this script to have orphans.  I usually just confirm movie is in library then add it to ignore list.
#    4) STACKEDDB ENTRY FOUND: /home/soukenka/movies/The Lord of the Rings: The Two Towers (2002)/stack:///home/soukenka/movies/The Lord of the Rings: The Two Towers (2002)/The.Lord.Of.The.Rings.The.Two.Towers.Extended.Edition.720p.HDTV.DTS.x264-THOR.disc1.mkv , /home/soukenka/movies/The Lord of the Rings: The Two Towers (2002)/The.Lord.Of.The.Rings.The.Two.Towers.Extended.Edition.720p.HDTV.DTS.x264-THOR.disc2.mkv
#    Sometimes 2 files are stacked in the database so output is put here usually not a big deal
### Author & Credits ###
# written by Eric Soukenka
# any questions contact at [email protected]
# Some code and logic were used from
#     http://wiki.xbmc.org/?title=Linux-Script_To_Find_Not_Scraped_Movies
# This is open source use it however you like!
### Requirements  ###
# python-pysql2  (For me I just did sudo apt-get install python-pysqlite2)
# python
# Have not tested on windows machine but should run fine.  If you have any
# issues with this or it runs successfully please let me know.
### Instructions  ###
# Setup the variables in the settings section following instructions for entries.
# Accepts 2 parameters
#       dbonly and fsonly.  They each perform what one would consider the logical choice :)
import re,sys,os
from pysqlite2 import dbapi2 as sqlite
### Settings ###
#usually just change your username here
DBLITE = "/home/soukenka/.xbmc/userdata/Database/MyVideos34.db"
#files home location
FILESHOME="/home/soukenka/downloads/torrents/"
#this is NOT case sensitive sample will ignore all variants of sample will block sAmPLE
#sorry you need to be careful here if you put in just for instance e it will ignore all files and directories with an e so make unique!
EXECPTIONLIST=['documentaries','upcoming.movies','sample','/musicvideos','mummy','2lions-Team','DVDr-sailo','narnia','THE_DARK_KNIGHT','incomplete/']
#during our file system search we will search for all files with these extensions and see if file exists in database
VALIDEXTENSIONS= ["MKV", "AVI", "FLV", "WMV", "AAF", "3GP", "ASF", "CAM", "M2V", "SWF", "FLA", "M4V", "MOV", "MPEG", "OGG", "RM", "MP4","MPG","IFO","VOB","IMG","ISO"]
### functions    ###
def fileFinder(dir_name, subdir, extArray=""): #directory name to start, true/false if you want recursive, pass an array of extension if you wish to filter
    fileList = []
    try:
        for file in os.listdir(dir_name):
            try:
                dirfile = os.path.join(dir_name, file)
                if os.path.isfile(dirfile):
                    if (extArray==""):
                        fileList.append(dirfile)
                        #print "1:"+dirfile
                    else:
                        if os.path.splitext(dirfile)[1][1:].upper() in extArray:
                            #print "2:"+dirfile
                elif os.path.isdir(dirfile) and subdir:
                    fileList.extend(fileFinder(dirfile, subdir, extArray))
                    #print "3:"+dirfile
            except UnicodeDecodeError:
                #need to figure out how to resolve this encoding error!
                print "Internal Error!  Unicode error found with: "+file;
                pass;
        return fileList
    except OSError:
        return "0"
### working code ###
connection1 = sqlite.connect(DBLITE)
cursor1 = connection1.cursor()
connection2 = sqlite.connect(DBLITE)
cursor2 = connection2.cursor()
try:
    if(sys.argv[1]=="fsonly"):
        show="fsonly";
    elif(sys.argv[1]=="dbonly"):
        show="dbonly";
    else:
        show="all";
except IndexError:
    show="all"
if(show=="fsonly" or show=="all"):
    files=fileFinder(FILESHOME,True,VALIDEXTENSIONS)
    for file in files:
        label=""
        skipIt=False;
        i=0;
        trimPath,trimFilename = os.path.split(file)
        query='select strPath,strFilename from path, files where path.idPath = files.idPath and strPath="'+trimPath+'/" and strFilename="'+trimFilename+'" order by strPath, strFilename'
        cursor1.execute(query);
        for row in cursor1:
            i=i+1
            for exc in EXECPTIONLIST:
                if(re.match('.*'+exc.upper()+'.*',file.upper())):
                    skipIt=True;
                else:
                    if(skipIt!=True):
                        skipIt=False;
                    pass;
        if(i==0):
            skipIt=False;
                    skipIt=True;
                else:
                    if(skipIt!=True):
                        skipIt=False;
                    pass;
            if(skipIt):
                #label="SKIPPING FILE: "
                pass;
            else:
                label="ORPHANFS ENTRY FOUND: ";
                pass;
        elif(i>1):
            label="ERROR DUPLICATE DATABASE ENTRIES: "
        if(label!=""):
            print label+file
if(show=="dbonly" or show=="all"):
    query='select strPath,strFilename from path, files where path.idPath = files.idPath order by strPath, strFilename'
    for row in cursor1:
        label=""
        found=False;
        dbFile=row[0]+row[1];
        if(len(row[0]) > 3):
            files=fileFinder(row[0],False);
            for file in files:
                if(file==dbFile):
                    found=True;
            if(found):
                pass;
            else:
                skipIt=False;
                    if(re.match('.*'+exc.upper()+'.*',dbFile.upper())):
                        skipIt=True;
                    else:
                        if(skipIt!=True):
                            skipIt=False;
                if(skipIt):
                    pass;
                else:
                    if(re.match('.*stack:\/\/.*',dbFile)):
                        print "STACKEDDB ENTRY FOUND: " +dbFile
                    elif(re.match('.*rar:\/\/.*',dbFile)):
                        print "RAR ENTRY FOUND: " +dbFile
                    else:
                        print "ORPHANDB ENTRY FOUND: "+dbFile
                pass;
print "Complete...";
may i suggest that a script of this nature would be best served up on http://gist.github.com. who knows, it could grow into a bigger product with some coordinated social development.
Thanks, this could come in handy. I did notice a problem with videos watched with video plugins (Apple Trailers, Mythbusters, etc.) They show up as
ORPHANDB ENTRY FOUND: http://movies.apple.com/movies/dreamworks/shrekforeverafter/shrek4_tlr1_h640w.mov?|User-Agent=QuickTime%2F7.2+%28qtver%3D7.2%3Bos%3DWindows+NT+5.1Service+Pack+3%29
ORPHANDB ENTRY FOUND: http://www251.megavideo.com/files/eaef73f71207bfb26a2300a83ccd080c/?.flv
and I have a bunch of them. I'm going to use this script with | grep ORPHANFS since I care more about that sort of thing.
Hello DDM123,
Please note that this script has two parameters you can run it with either dbonly or fsonly. In your situation just run scriptname.py fsonly
It is true the orphandb stuff needs some work I only run it now and then just to see if things are looking right.
I will improve on script as time allows. If people keep documenting issues I will make improvements to script thank you for leaving feedback.
I really like Gist been playing with it thank you for suggestion I will use it.
