2010-01-09, 18:59
2010-01-09, 18:59
2010-01-10, 18:09
nice one! although a bit too "screamy" for my taste, but all the logos looks neat
anyway while on the subject, when I change my splash screen it doesn't show up in fullscreen (1080p), it's scaled down and centered to what looks something like 720p. Does this happen for you guys aswell? And does anyone know if there's any setting to change this behavior to just display the image instead of scaling it first?
2010-01-10, 19:31
2010-01-10, 19:54
strange question, but I don't appear to have a media directory, or a splash.png file.
I've enable hidden files so I can see the .xbmc dir, but no media directory is contained within.
if I creat a media dir and copy the file in, then when I reboot the original splash screen still displays.
2010-01-10, 21:49
i presume you are running linux.
then it's in /usr/share/xbmc/media
2010-01-10, 21:55
blittan Wrote:i presume you are running linux.
I am yes.
Presuming you mean the .xbmc folder under home, or somewhere else?
If as I've typed above - I don't have a media folder under .xbmc.
Unless there are two xbmc folders?
2010-01-10, 22:01
/ = root
/usr/share/xbmc/media is the path
not under home directory
2010-01-10, 22:19
blittan Wrote:/ = root
ah cheers - thanks
2010-01-14, 00:55
awesome pic man, I read the link in the 2nd but it didn't help me, the file link was dead and I didn't see any info there. How would I go about making this image display full screen?
2010-01-14, 06:38
2010-01-15, 08:44
openelec.tv Wrote:with this patch :-)
http://bazaar.launchpad.net/~sraue/opene...h-0.1.diff
Good patch... maybe??
Inistructions on how to apply that patch would be nice
2010-01-15, 08:59
TheSwede1970 Wrote:Good patch... maybe??
hmmm how we can patch sources?
under linux with
cd /path/to/source
patch -Np1 -i /path/to/patch.diff
then compile the sources.
or made the changes by hand like the patch does - and then comile xbmc
2010-01-16, 16:13
openelec.tv Wrote:hmmm how we can patch sources?
under linux with
Code:cd /path/to/source
Hmm and if not Linux user?
Using Windows 7
2010-01-16, 17:21
TheSwede1970 Wrote:Hmm and if not Linux user?
Using Windows 7
uhm well just go and modify the three lines manually. I mean it is 3 lines of code.
I sort of suspect that you will not be doing this anyway and will not be re-compiling xbmc from source or even have the src on your windoze 7 box but just in case I am wrong I will tell you exactly what lines openelec.tv's patch alters.
Change lines 56 57 and 58 in source file TopLevelXbmcSrcDir/xbmc/utils/Splash.cpp (Where TopLevelXbmcSrcDir is whatever you called the dest dir when you did the svn checkout. trunk if you didn't specify)
Edit: heh well I guess in windows it would be TopLevelXbmcSrcDir\xbmc\utils\Splash.cpp actually
float w = g_graphicsContext.GetWidth() * 0.5f;
float h = g_graphicsContext.GetHeight() * 0.5f;
CGUIImage* image = new CGUIImage(0, 0, w*0.5f, h*0.5f, w, h, m_ImageName);
To:
float w = g_graphicsContext.GetWidth();
float h = g_graphicsContext.GetHeight();
CGUIImage* image = new CGUIImage(0, 0, 0, 0, w, h, m_ImageName);
then save and recompile.
That is it. Note I am not saying anything about how good or bad these changes are. I am simply telling you what the proposed changes were in the patch that openelec.tv suggested.
2010-01-18, 04:59
tronics Wrote:uhm well just go and modify the three lines manually. I mean it is 3 lines of code.
To:
Thanks might give that a go
