Full Version: Updatelibrary script help
ok I have been reading the wiki and searching but seem to have hit that place where it should work but doesn't seem to...
ok long story short, I have a python script that runs a bash script, I cannot seem to get xbmc-send command working in my bash...
testsudo.py - this calls the bash script in same directory (so I can launch from scripts section (I tried System.Exec in remote.xml but it would close xbmc). The idea is that I would use RunScript from remote.xml once I get it working
---testsudo.py--
import os
os.system('/home/htpc/.xbmc/scripts/testsudo')
testsudo - this is the bash script that unmounts and mounts my nfs share (long story has to do with smb/nfs mix not updating right), then runs the UpdateLibrary(video) command
--testsudo--
#!/bin/bash
sudo umount <path>
sudo mount -a
xbmc-send --action="XBMC.UpdateLibrary(video)"
The umount and mount command works (another battle with suboers fileSmile)
the xbmc-send command works from terminal (or seems to, says its sending the command).
But when I run testsudo.py from xbmc scripts section, the library doesn't seem to update (new files do show up in videos section but not movies section). I do not see the dialog of "scan for content" that I see when I run the XBMC.UpdateLibrary from remote.xml...
I have read that I could use curl/get via the http server but I would rather not turn it on so that is why I am trying the xbmc-send package/command...
Any ideas? I am willing to bet its something simple...
ok so I am now trying to do everything in py, which seems to be working... well except for the xbmc-send command
test.py
import os
os.system('sudo umount /home/htpc/Documents/Storage2')
os.system('sudo mount -a')
os.system('xbmc-send --action="XBMC.UpdateLibrary(video)"')
I saw references to command "import xbmc" I will play around with that
me again... I suspect there is some issue with running the scripts from within xbmc
I created a bash script with just:
--up script--
It kicks off the scan content process from either terminal or if I just make it executable and run it... So the command works great!!!
So I then adjusted by previous py to kick off the new up script, no go..
import os
os.system('/home/htpc/.xbmc/scripts/up')
So I must be calling this command wrong... maybe xbmc can't call it itselfHuh??
Funny thing is there isn't a script failed message in xbmc, just seems to run....
UPDATE
OK there doesn't seem to be anything wrong with my scripts. My python scripts work if I call them from terminal, everything else works too. Gotta try and find out why the xbmc-send won't work if called by xbmc...
OK I got it... amazing what reading through the python section of the wiki will do.... didn't understand half of it but I got it solved...
Here is my final working python script
import os
import xbmc, xbmcgui
xbmc.executebuiltin('XBMC.UpdateLibrary(video)')
