(2010-01-09, 23:38)althekiller Wrote: [ -> ]xbmc.org > support > forum > search . Seriously, this gets asked twice a week at least.
Alternatively, settings > video > library > clean.
here's where to look for the databases - delete the ones you have duplicates in and then redo your file locations in "add videos" and you'll be set. Be careful what you futz with under the hood - you can ftp into your system and copy over the databases FIRST as back ups.
Oh, and my comment still stands althekiller - you're no better for deleting it.
here's the info you need:
Location of the UserData folder
Android: Android/data/org.xbmc.xbmc/files/.xbmc/userdata/
iOS/ATV2: /private/var/mobile/Library/Preferences/XBMC/userdata/
Linux: $HOME/.xbmc/userdata/
Mac OS X: /Users/<your_user_name>/Library/Application Support/XBMC/userdata/
Windows Vista/7: Users\%userprofile%\AppData\Roaming\XBMC\userdata\
Windows XP: Documents and Settings\%userprofile%\Application Data\XBMC\userdata\
UserData folder contents
Below are the elements contained in the UserData folder and their role:
Database - This is where all of the databases required for your Music and Video Libraries are located, containing any downloaded (scraped) music or video information.
MyMusic18.db - Database file containing Music information.
MyPrograms6.db - Database file containing Program information.
MyVideos60.db - Database file containing Movie, TV Show and Music Videos information.
ViewModes4.db - Database file containing information on all XBMC views (viewmode, sorting etc.).
Addons15.db - Database file containing information on all XBMC addons (skins, scraper, video-addons...).
Textures6.db - Database file containing information on all XBMC textures (thumbs, fanart, posters...).
TV16.db - Database file containing information on Live-TV channels (experimental PVR-builds only!).
EPG5.db - Database file containing information on EPG for Live-TV (experimental PVR-builds only!).
