Full Version: [Appletv] Audio Device Detection Bug
MAC OS 10.4
Platform AppleTv 3.01
Launcher version 3.21
Install Method Launcher
XBMC 9.11 SVN Revision 26558
File information
Container MKV
Mediainfo Output:
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : A_AAC
Duration : 2h 6mn
Channel(s) : 6 channels
Channel positions : Front: L C R, Rear: L R, LFE
Sampling rate : 48.0 KHz
Language : English
XBMC Log
Hardware
AppleTv with CrystalHD (the problem occurs with and without the card installed)
KEF instant theather kit570w
When I play files with AAC audio the play incorrectly in XBMC, the system seem to detect the wrong number of channels (4 as opposed to 6 in this case) so that the center and the subwoofer do not produce any sound
If I play the same files in Boxee or Nito (though in this case they would skip many frames) the receiver is correctly detected and the whole channels play
The same file plays fine with XBMC 9.04 and previous versions
Please help as this is really bugging me and rendering 50% of my assets unwatchable on XBMC
There seems to be an issue with all files that have spectral band replication in XBMC for apple tv
I found a workaround extracting the tracks, converting AAC to AC3 and remuxing
With the new MKV (H264+AC3) Xbmc correctly decodes the audio
With the AAC I tried to remux in m4v and I get the error audio undertermined
What do I have to do to submit official a bug?
interceptor121 Wrote:What do I have to do to submit official a bug?
make a trac ticket, describe the problem, include a sample to reproduce the problem and bonus points for a patch that fixes the problem.
Done
I found a workaround demuxing, converting the AAC to AC3 and then remuxing but it is tedious
I submitted the trac ticket http://trac.xbmc.org/ticket/8465
I would like to know if other people have the same issue with the sample file
