Full Version: Is there any way to make multiple drives appear as one?
As the topic says..
I have DVD files (video_ts files in folders) across 2 drives (G,H) Is there any way to make them appear as one location in XBMC, as opposed to having to select the individual drive? I'd like to be able to select "Videos", and have all my movies appear.
Thanks...
BTW, forgot to mention that the drives are shared on a Vista desktop, and streamed to my HTPC that will be running XBMC
When you add sources, there is an additional add source button... you can combine as many folders into one as you would like.
outleradam Wrote:When you add sources, there is an additional add source button... you can combine as many folders into one as you would like.
Would you perhaps give me, or point me to a step, by step? When I add sources, it just appears as a separate location. Or am I clicking the wrong "add source" button?
Sorry I brand new at XBMC..
Thanks again...
then when going into your source, you'll have content from both Smile
Edit:
Nevermind...someone explained it better above!
dtviewer Wrote:Edit:
Actually you explained it the easiest. Good thing I read it before you edited it. The poster above you helped with the visuals..
Now the next dumb question: How do I make the titles on BOTH drives appear alphabetically. Right now they sorted alphabetically PER drive.
Thanks again for all the help..
