Full Version: Custome Home Panel Icons correctly?
Is there a way to get Custom Home Panel Icons to work in such a way that it shows just the movie fanart on the movies tab and just the tvshows fanart on the tvshow tab etc?
I only know how to select the fanart folder that contains all of them:/
This is what you're after.
Use that script, and then point Xperience to the separate folders that it produces. I just tested it, and it works fine.
I found it easiest to point X at a random folder for each option, then go into guisettings.xml to change the path to special://userdata/script_data/Video Fanart Splitter/Movies/ or /TV/
Thank you very muchSmile
