2010-01-12, 02:40
some of my tv recordings are only being detected by XBMC as 540p when they should be 720p, here is part of the log file.
is say it is 960x720 PAR 4:3, DAR 16:9. this is how UK widescreen tv is broadcast, when played it is 1280x720 is they anything i can do without creating an nfo ?
PHP Code:
00:30:59 T:2958364672 M:7307329536 DEBUG: ffmpeg[B0551000]: [matroska] Estimating duration from bitrate, this may be inaccurate
00:30:59 T:2958364672 M:7307509760 DEBUG: Open - av_find_stream_info finished
00:30:59 T:2958364672 M:7307509760 INFO: ffmpeg[B0551000]: Input #0, matroska, from '/Volumes/TVShows/The Day of the Triffids/The.Day.of.the.Triffids - s01e01.hdtv.mkv':
00:30:59 T:2958364672 M:7307509760 INFO: ffmpeg[B0551000]: Duration: 01:28:59.88, start: 0.000000, bitrate: N/A
00:30:59 T:2958364672 M:7307509760 INFO: ffmpeg[B0551000]: Stream #0.0(eng): Video: h264, yuv420p, 960x720 [PAR 4:3 DAR 16:9], 25 fps, 200 tbr, 1k tbn, 50 tbc
00:30:59 T:2958364672 M:7307509760 INFO: ffmpeg[B0551000]: Stream #0.1(eng): Audio: ac3, 48000 Hz, 6 channels, s16
