2010-01-12, 12:52
Problem appears to be resolved in a more current SVN - export at 30% without a pause.
Original post
Hi there,
As part of a migration of my network attached storage (i.e. the server name and path to my shared folders has changed) I am trying to export my library using the single files option. For some reason I am hitting an error "Unable to write to folder" - this occurs repeatably for particular folders and not for others. I have checked the folder permissions and gone as far as setting inheritence on user access and attributes to insure all are common.
The only thing I can see is that the folders that fail have very long file names for the .avi - the folder length doesn't seem to matter.
Is this a known issue? Is there a work around? With a very large library I am keen to get the export to work to maintain my 'watched' flags and bring across the thumbnails - however open to other suggestions.
Addendum: this is making TV episodes impossible to export (episode names etc).
Cheers,
Gmk2
Original post
Hi there,
Cheers,
Gmk2
