Full Version: No audio following a fresh install
I was using XBMC on Ubuntu 8.10 and had installed it previously using one of the minimal install guides. I remember having a fehttp://wiki.xbmc.org/?title=XBMCbuntuw issues with sound then but stupidly did not make a note of what I did.
Any way, a couple of days ago my install started to play up so I thought I would do a fresh one based on Ubuntu 9.10. Everything seems to have gone fine and XBMC starts automatically as expected but I have no sound.
My system is based on a ASUSTek Motherboard M3N78-VM and connects to the TV with a HDMI cable. The guide I followed was this one - http://wiki.xbmc.org/?title=XBMCbuntu
I have done a minimal install so can not play with settings in Gnome etc, however I can run:
speaker-test -twav -c6 -Dplug:hdmi
and hear sound (I only get front left and front right).
If I go into XBMC and select a video, all I get is white noise, If I play around with the audio settings in XBMC the white noise stops and I get nothing else.
It is driving me mad and I am sure it is a simple setting somewhere!
You're having the usual PulseAudio issues
There are quite a few solutions in that forum topic.
If you have a pretty much dedicated HTPC and use spdif... (aka not a workstation + htpc)...
This is what I did to get sound working in xbmc...
Remove PulseAudio
Terminal: sudo apt-get purge pulseaudio
This will get spdif working for movies in xbmc but you will probably have issues with non-pass through audio aka mp3 and internal sound in ubuntu.
To fix this...
Terminal: sudo alsamixer
Find and unmute all iec958 outputs, you can unmute by pressing < or > should turn from MM to 00 (and green)
