Full Version: Looking for a command to detect playback
I use SABnzbd on the same Karmic box as I run XBMC and I'm looking to pause SABnzbd's downloading whenever XBMC is playing media to avoid choppy playback during post processing of a download.
I know how to send a command to SABnzbd to pause and resume downloading but I'm looking for a bash or python command I can use to detect whether XBMC is currently playing media or not. Any ideas?
Rob
You could check the Web API, there is a GetCurrentlyPlaying() command. Looks like it will return Filename:[Nothing Playing] if nothing is playing, and media info if something is playing. Worth checking out.
http://wiki.xbmc.org/?title=Web_Server_HTTP_API
The command you want is at the top of the Command Reference Table.
that is perfect. Thank you much
tret Wrote:...
I'm looking for a .. or python command I can use to detect whether XBMC is currently playing media or not
#!/usr/bin/python
import sys
import re
import httplib
# webservice host/port
HOST = 'localhost'
PORT = 8081
# nothing playing regex
NO_PLAY = re.compile('Filename:\[Nothing Playing\]')
h = httplib.HTTP(HOST, PORT)
h.putrequest("GET", "/xbmcCmds/xbmcHttp?command=GetCurrentlyPlaying()")
h.endheaders()
stat, statm, head = h.getreply()
if not re.search(NO_PLAY, h.getfile().read()):
    print "File playing"
    sys.exit(1)
print "Nothing playing"
sys.exit(0)
