2010-01-12, 20:32
I got the following issue: Whenever I update my movie library XBMC just shuts down. Since I installed 9.11 final release I rebuild my library from scratch, it scraped a couple of movies fine but at some point it started crashing.
I looked up the last good scraped movie, moved the one it crashes on to another location, rescanned the library, couple of movies fine and then again a crash.
Now the temp moving of the movies doesnt work anymore, XBMC just crashes on me.
Here is what I've done so far:
- enabled debug in advanced settings (http://pastebin.ca/1748568) : No errors appear in the log when it crashes
- searched through the forum: no similar problems found
- scanned my HDD for bad blocks using XP error checking, defragmented, did some checkups using seatools and the drive passed all the tests: it still crashes
I had no problems with the previous version of XBMC whatsoever... And I have no problems with my TV library which is much bigger...
Does someone have another trick in his sleeve to troubleshoot this? I'm clueless atm...
