(2014-04-20, 13:48)linqcan Wrote: [ -> ] (2014-04-20, 13:46)Crall Wrote: [ -> ] (2014-04-20, 13:41)linqcan Wrote: [ -> ]That's because you are running an old version of an experimental branch. I would recommend you to use the official version from the XBMC repository as it is working.
Strange. Mine did not work with the official either... Will try it again. Thanks
In that case you need to specify what is not working and file an issue report here: https://github.com/nilzen/xbmc-svtplay/issues
I am able to list program using "Category"->"Barn" as well as playing a program from there.
Installed the official again and now it listed the programs under barn. Got script error trying to start a episode but after hammering the episode it started... Will run it and report on git if more issues. Thanks!
Using the experimental version found here,
https://github.com/nilzen/xbmc-svtplay/issues/70 (suggested in earlier post), Programs A-Ö no longer works.
Other than that I have found no errors with this version and I want to keep using experimental to be able to use Live broadcasts. Is there a newer version?
(2014-04-20, 20:44)Novin Wrote: [ -> ]Using the experimental version found here, https://github.com/nilzen/xbmc-svtplay/issues/70 (suggested in earlier post), Programs A-Ö no longer works.
Also all Categories are empty.
XBMC rc1
(2014-05-02, 23:29)Novin Wrote: [ -> ] (2014-04-20, 20:44)Novin Wrote: [ -> ]Using the experimental version found here, https://github.com/nilzen/xbmc-svtplay/issues/70 (suggested in earlier post), Programs A-Ö no longer works.
XBMC rc1
Do not use the experimental versions if you are not testing (the one you linked to was for testing a playlist feature and not meant for daily use). Use the official version, it works.
(2014-05-13, 14:29)linqcan Wrote: [ -> ] (2014-05-02, 23:29)Novin Wrote: [ -> ] (2014-04-20, 20:44)Novin Wrote: [ -> ]Using the experimental version found here, https://github.com/nilzen/xbmc-svtplay/issues/70 (suggested in earlier post), Programs A-Ö no longer works.
XBMC rc1
But not for live broadcast so there is my dilemma
(2014-05-15, 21:44)Novin Wrote: [ -> ] (2014-05-13, 14:29)linqcan Wrote: [ -> ] (2014-05-02, 23:29)Novin Wrote: [ -> ]Also all Categories are empty.
XBMC rc1
True. Was disabled due to compability issues with XBMC 12.0.
If you are hacky you can enable it by removing the hashmark/comment from line 83 in "default.py":
https://github.com/nilzen/xbmc-svtplay/b...ult.py#L83
I am referring to the stable/official version of the plugin now, please make sure you have that one installed first.
There will be no more updates for frodo until the new site is released ("before summer").
There seems to be some updates on the svt play today, I can't get this addon to work anymore. Some known changes?
Thank you! Really appreciate your work with this!
(2014-06-05, 12:28)linqcan Wrote: [ -> ] (2014-06-03, 17:18)linqcan Wrote: [ -> ] (2014-06-03, 16:32)dumbo Wrote: [ -> ]There seems to be some updates on the svt play today, I can't get this addon to work anymore. Some known changes?
Yes, a new site was launched today. An update to the addon will be out soon.
http://blogg.svt.se/testbild/2014/06/ett...gare-play/
XBMC has accepted the update. Note that XBMC 13 (Gotham) is required to use SVT Play now. The "frodo" branch will not be updated anymore.
http://xbmc.org/xbmc-13-0-gotham-rises/
Hey!
Just installed XBMC 13 (Gotham) but can't get the SVT Play plugin to work. It is still V3.3.5 by nilzen. Have uninstalled and reinstalled it but still no programs to watch, all folders are emty. Any clue what I'm doing wrong?
//Bjarnek
The new version 4.0.0 of SVTPLAY Add-On solves the problem with the new source site.
I got mine updated by rebooting the Pi (I am running RASPBMC).
I'm not getting any fanart on SVT Play, is that normal? Posters work good and playing content works fine. I'm using the latest version, Gotham 13.1 and tried different skins.
