(2014-06-29, 15:45)linqcan Wrote: [ -> ]Can anyone confirm that this* is an issue on ATV2 running XBMC 13.1 and SVT Play 4.0.3?
*https://github.com/nilzen/xbmc-svtplay/issues/98
I have tested with SVT Play 4.0.3 and XBMC 13.0-BETA3 on ATV2. No channels work. One livestream tested (SM-veckan: Boule) working.
Edit: tested livestream of Sportnytt: not working.
(2014-06-30, 21:32)kokangit Wrote: [ -> ] (2014-06-29, 15:45)linqcan Wrote: [ -> ]Can anyone confirm that this* is an issue on ATV2 running XBMC 13.1 and SVT Play 4.0.3?
Thanks for verifying it for me!
Would you be able to extract a log file (in which the issue is triggered) with both XBMC and SVT Play debug enabled and put it in the issue on Github?
I don't have access to an ATV2 myself unfortunately.
Of course! I will do that as soon as I find the time. Hopefully tonight.
Idea for a feature:
Make a new category in the root with your X latest currently playing items. Items that you have started but not completed.
Is this a reasonable feature request? Since you can resume items it sounds possible to create it with the data in XBMC.
(2014-07-03, 22:25)linqcan Wrote: [ -> ]Teaser, in the next update (due this weekend) "favorites" are added. You can add a show ("program") as a favorite. No more clicking insanity to find your favorite shows!
https://github.com/nilzen/xbmc-svtplay/issues/99
Is it supposed to work?
I tried adding something and got some error with .py in it. Also choosing favorites from the main menu generates an error too.
(2014-09-28, 21:48)Novin Wrote: [ -> ] (2014-07-03, 22:25)linqcan Wrote: [ -> ]Teaser, in the next update (due this weekend) "favorites" are added. You can add a show ("program") as a favorite. No more clicking insanity to find your favorite shows!
Is it supposed to work? I tried adding something and got some error with .py in it. Also choosing favorites from the main menu generates an error too.
I have the same problem -- adding to favourites 'work' (i.e. no message), but then choosing them does just render an error message.
First, thank you for a great add on.
I have issues with favorites as well,but slightly different from previous posts.
Until a few days ago, I could add favourites from Categories (ie Nyheter). On a side not I got script error when trying to add from Program A-Ö (ie Aktuellt) and never got it to work.
Then a few days ago the Favourites from Categories (ie Nyheter) stopped working with a script error. Now I cannot even enter Categories, but only get a script error. I am not made any updates on SVT Play, but installed other add ons such as iStream. The python scripts in the add on folder all have 18 sept as date which is likely when I updated last.
Looking in the log file it states "IndexError: list index out of range" pointing to line 362 and 162 in default.py and line 97 in svt.py
Running SVT Play 4.0.6 on Gotham 13.3 on Minix X8-H with Android 4.4.2
ignore
Fantastic! Thank you.
I am still not able to add a program directly from "Catergories" or "Program A-Ö" such as "Aktuellt" to favourites and there are no error messages. This is minor since for news I just add "Nyheter" which is only one click away, but if it is easy to fix it would be appreciated.
Still broken, the only thing that works is Channels
I'm using 4.0.7
UPDATE: It worked yesterday, but now I get script error independent on choice. I presume that is what Myl1ttlepwny had already seen.
For me the favorites work in the sense I cannot enter Favorites inside this addon as well as add favorites from Categories. I still cannot add from Program such as Aktuellt.
This worked after I replaced svt.py and favouritesmanager.py and kept all other files as they were.
Hi there! I made a thread just before I noticed this post but I'll try and ask my question here as well:
Is there anyone who knows of an addon/repo that has the standard live TV channels (TV3, Kanal 5 and TV6 etc)?
