The addon was updated 2 days ago in github.
The address is available in post #424.
I suppose there will be an update available.
In case you can't wait you have to replace svt.py and default.py.
(2015-12-20, 20:50)ToddeSwe Wrote: [ -> ]Is this addon discontinued?
Is not updated since 2010 from what I can see.
Guess you're looking at the outdated google code link, but
au contraire
I installed the addon two days ago (OSMC on a Raspberry Pi 2). First day it worked perfectly with live video but yesterday and today I only get an error. I'm using VPN and everything works on a PC (using the same vpn) but on the raspberry it seems that I can only watch program that are available outside Sweden. Any thoughts?
20:07:07 4367.680664 T:1665664032 NOTICE: Thread JobWorker start, auto delete: true
20:07:12 4372.643555 T:1587831840 NOTICE: Thread LanguageInvoker start, auto delete: false
20:07:12 4373.064941 T:1587831840 NOTICE: -->Python Interpreter Initialized<--
20:07:13 4374.195801 T:1587831840 NOTICE: CommonFunctions-2.5.1
20:07:13 4374.261230 T:1587831840 NOTICE: [SVT Play 4.0.21] <module> : '{'url': '%2Fkanaler%2Fsvt2', 'mode': 'video'}'
20:07:14 4374.539551 T:1587831840 WARNING: Attempt to use invalid handle 26
20:07:14 4375.009766 T:1957659184 ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for https://svt12-lh.akamaihd.net/i/svt12_0@77507/master.m3u8?__b__=563
20:07:14 4375.053711 T:1957659184 NOTICE: DVDPlayer: Opening: https://svt12-lh.akamaihd.net/i/svt12_0@77507/master.m3u8?__b__=563
20:07:14 4375.053711 T:1957659184 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:07:14 4375.054199 T:1587831840 NOTICE: Thread DVDPlayer start, auto delete: false
20:07:14 4375.054688 T:1587831840 NOTICE: Creating InputStream
20:07:14 4375.409180 T:1587831840 ERROR: CCurlFile::FillBuffer - Failed: HTTP returned error 403
20:07:14 4375.409180 T:1587831840 ERROR: CCurlFile::Open failed with code 403 for https://svt12-lh.akamaihd.net/i/svt12_0@77507/master.m3u8?__b__=563
20:07:14 4375.409668 T:1587831840 ERROR: Open - failed to open source <https://svt12-lh.akamaihd.net/i/svt12_0@77507/master.m3u8?__b__=563>
20:07:15 4375.410156 T:1587831840 NOTICE: Creating Demuxer
20:07:15 4375.774902 T:1587831840 ERROR: OpenDemuxStream - Error creating demuxer
20:07:15 4375.775391 T:1587831840 NOTICE: CDVDPlayer::OnExit()
20:07:15 4375.776367 T:1957659184 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.svtplay/?url=%2Fkanaler%2Fsvt2&mode=video]
20:07:15 4375.776855 T:1957659184 NOTICE: CDVDPlayer::CloseFile()
20:07:15 4375.777344 T:1957659184 NOTICE: DVDPlayer: waiting for threads to exit
20:07:15 4375.777344 T:1957659184 NOTICE: DVDPlayer: finished waiting
20:07:15 4375.777344 T:1957659184 NOTICE: CDVDPlayer::CloseFile()
20:07:16 4377.144531 T:1587831840 NOTICE: Thread BackgroundLoader start, auto delete: false
Thanks for a very good addon!
UPDATE, it was a DNS problem with the VPN. Now everything works!
Channel listing stopped working for me all of a sudden. Picking specific episodes is fine still.
(2016-03-02, 19:49)ghallberg Wrote: [ -> ]Channel listing stopped working for me all of a sudden. Picking specific episodes is fine still.
it did not work yesterday, but today it works again..
the error message (when starting the debug setting on svtplay plugin)
NOTICE: [SVT Play 4.0.21] <module> : '{'mode': 'kanaler'}'
NOTICE: [SVT Play 4.0.21] fetchPage : 'called for : {'link': 'http://svtplay.se/kanaler'}'
NOTICE: [SVT Play 4.0.21] fetchPage : 'Got request'
NOTICE: [SVT Play 4.0.21] fetchPage : 'connecting to server...'
NOTICE: [SVT Play 4.0.21] fetchPage : 'Done'
NOTICE: [SVT Play 4.0.21] errorMsg : 'Error: No container found for channels'
Today SVT has changed something making the programs non-playable.
Same thing happened with the Retrospect addon so it's definitively a change.
En stor kram till den som fixar!!
Svt on retrospect works for me
Hey!
It's like dobbelina is saying, most of the programs are non-playable
. I'm running Kodi 15.2 on Windows 7 Enterprise 64bit.
Regards
Bjarnek
Can you give example of program that doesn't work?
Jämtlandsnytt, Rapport, Uppdrag Granskning are some that won't work.
Some programs are working and other are not. I think it might be a change of urls from the provider Akamai which SVT uses. As you can see in this extract from my log
http://ix.io/r5I. The working stream ends with *.m3u8 while the other non-working ends with extra info. Somehow it fails finding the stream. The actual url of the stream[1] works however. I tried it with Mpv.
[1]
http://svtplay14p-f.akamaihd.net/i/world...aster.m3u8
A temporarily fix that works:
Disable both "use avc 1.77.30 streams" and "Set bandwidth manually" in settings for the xbmc-svtplay addon.........
