2010-01-13, 00:42
I have a lot of TV show (mainly anime) that are found in theTVdb, where a regex is able to enumerate the episode numbers correctly but that are not added to the library. However, a few series do actually get added.
I run XBMC 9.11 on a diskless PXE booted Gentoo machine.
I already tried different valid regexes with which XBMC can correctly enumerate the episode numbers. I don't use any tvshows.nfo files. But XBMC keeps complaining about "make sure the <episodeguide> tag is in place"...
for example this series: http://pastebin.com/m1a0d2ce8
As you can see, the show is found and valid <episodeguide> tags are returned. I checked the returned zip-file and it contains xml files describing the individual episodes.
Also the episodes are correctly found as (e1), (e2), (e3), ....
But then on line 20 there is a PCRE error "Match limit reached" and then XBMC starts complaining about a missing episodeguide...
The shows reside in a structure like this
Is this an error in the theTVdb data? which I find hard to believe as 70% of the series I have get this same type of behaviour. And about 25% is actually correctly added.
Or is this a bug in the scraper?
Or an error in my configuration or filenaming?
Anime <-- scraper: theTVdb, absolute numbering enabled
\- <Series name>
\- <Series episode>
