2010-01-19, 04:24
2010-01-19, 17:57
@ Evin
I don't believe you should be doing
On Ubuntu su is used to elevate the existing user to admin. Alternately, if you chose not to use sudo (you did not disable root) in the installation, then you would need to do su at a terminal to switch to the root user account.
sudo su
2010-01-21, 03:29
pashdown Wrote:Code:3d 0xa5
advance 0xac
angle 0x8a
audio 0x4f
chptr+ 0xdf
chptr- 0xdd
clear 0xf9
discskip 0xb3
eject 0xaf
hdmi 0xfa
inputnext 0xb8
mode 0x89
opendv 0xbf
pwroff 0xc5
pwron 0xd5
random 0xb5
repeat 0x6b
replay 0x45
return 0xd8
skipback 0xdd
subtitle 0x7f
zoom 0x6f
I can post my 880 codes too except I don't know which are "extra" buttons and which are needed/used by XBMC.
2010-01-23, 20:36
sygyzy_nbr Wrote:I can post my 880 codes too except I don't know which are "extra" buttons and which are needed/used by XBMC.
Yes! Please post the 880 codes. Thanks.
2010-01-23, 22:30
I am having this weird problem where depending how I setup the activity (play game, play dvd, watch my videos), I get different buttons on the LCD screen. What did you use as your "Activity" setup hogfan?
2010-01-24, 00:01
i have the harmony one remote
this setup didnt work for me
when running irw i get the following on a certain button press:
i then go to /usr/share/lirc/remotes/mceusb/lircd.conf.mceusb and already see BB2 defined there
then i go to the /usr/share/xbmc/system/Lircmap.xml file and set
then in the remote.xml and add the following right under global and <FullscreenVideo>
test the button when viewing a movie and subtitles dont toggle
what am i missing here?
000000037ff07bb2 00 BB2 mceusb
#bb2 - bb4 unused
BB2 0x00007bb2
BB3 0x00007bb3
BB4 0x00007bb4
<obc117>BB2</obc117>
<universalremote>
<obc117>ShowSubtitles</obc117>
</universalremote>
2010-01-28, 22:25
Wish I had this about 4 weeks ago ... excellent guide.
2010-02-01, 14:40
ohoffm Wrote:when attempting to run:
sudo mode2 -r -d /dev/lirc0
I am getting the following error:
mode2: error opening /dev/lirc0
mode2: No such file or directory
and that device does not exist.
I got the same problem! I use an ION based board (asus at3n) and the remote of an old ati theater 550 tuner like this The remote has an usb receiver wich is work well with the base function (left right up down ok=enter playing navigates, volume up down etc.) without lirc too. I can use it with a basic desktop ubuntu too, so I think it's independent of the lirc. Lsusb output is:
Bus 004 Device 002: ID 0766:0204 Jess-Link Products Co., Ltd
I tried with "irw", and it works but almost all of the buttons have the same output :ˇ@
So, the question is: what I use, as the name of the device in the begining
lirc.conf and why Ihave no /dev/lirc0 any idea??
Sorry for my bad english!
2010-03-21, 02:01
I have lircd.conf file set with the codes from the first page.
I started irw and it takes me to a blank line. I am using an actual xbox 360 dvd remote that looks like this and a usbuirt.
When I press a button on the remote after entering irw, I do not get any codes. The light on the usbuirt flashes, but no codes.
Any suggestions?
Any suggestions?
2010-03-21, 10:57
frustrated is the word..
Does anyone have a hardware.conf and lircd.conf they would be willing to share so i can use it as a template.
Someone using a harmony and a usbuirt.
2010-03-25, 22:25
Can I just check before putting my hand in my pocket, this is the XBOX dongle(controller) I need to buy?
http://www.amazon.co.uk/Official-Movie-P...B0000CFYI8
Cheers!
Cheers!
2010-03-27, 19:12
nickhopkins08 Wrote:Can I just check before putting my hand in my pocket, this is the XBOX dongle(controller) I need to buy?
Cheers!
Yes!
2010-03-27, 20:36
2010-03-31, 02:18
i got as far as pasting in the 2nd line and got this
GNU nano 2.0.9 File: /etc/lirc/lircd.conf
#This configuration has been automatically generated via
#the Ubuntu LIRC package maintainer scripts.
#It includes the default configuration for the remote and/or
#transmitter that you have selected during package installation.
#Feel free to add any custom remotes to the configuration
#via additional include directives or below the existing
#Ubuntu include directives from your selected remote and/or
#transmitter.
#Configuration for the Windows Media Center Remotes (new version Philips et al.$
include "/usr/share/lirc/remotes/mceusb/lircd.conf.mceusb"
[ Read 14 lines ]
^G Get Help ^O WriteOut ^R Read File ^Y Prev Page ^K Cut Text ^C Cur Pos
^X Exit ^J Justify ^W Where Is ^V Next Page ^U UnCut Text^T To Spell
no idea
#transmitter.
[ Read 14 lines ]
no idea
2010-03-31, 11:52
Will the below work for plugging the XBOX IR dongle into my PC? I'm having problems with the website suggested on the first page:
http://www.play-asia.com/paOS-13-71-6m-4...0-czu.html
