2015-11-06, 03:59
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
2015-11-06, 07:36
Ripping your disks is still the best kodi option.
2015-12-03, 16:01
I Finally get was I was looking for using makeMKV, the issue was that when I installed prior day it was on the night after 14 hours working and my mind shouldn't be lucid, I had installed XBMC add-on but not the makeMKV itself.
I tested a pair of original blurays I own and seem't to work
2015-12-22, 23:40
Hello!
I have problem
Kodibuntu - 15.2
1. I installed the plugin: https://github.com/X-dark/plugin.makemkv.../1.1.3.zip
2. I installed makemkvcom using a script: http://146.185.132.52/ubuntu/apps/files/buildMakeMkv.sh
3. The plugin an error:
log:
00:32:58 T:139637463594752 NOTICE: -->Python Interpreter Initialized<--
00:32:58 T:139637463594752 NOTICE: [BR 1] Starting the BluRay script
00:32:58 T:139637463594752 NOTICE: [BR 1] args
00:32:58 T:139637463594752 NOTICE: [BR 1] plugin://plugin.makemkvbluray/
00:32:58 T:139637463594752 NOTICE: [BR 1] 1
00:32:58 T:139637463594752 NOTICE: [BR 1] done args
00:32:58 T:139637463594752 NOTICE: [BR 1] Staring
00:32:58 T:139637463594752 NOTICE: [BR-settings 1] reading settings
00:32:58 T:139637463594752 NOTICE: [BR-settings 1] raw param string:
00:32:58 T:139637463594752 NOTICE: [BR 1] mode: None
00:32:58 T:139637463594752 NOTICE: [BR 1] Showing categories
00:32:58 T:139637463594752 NOTICE: [BR-makemkvinteraction 1] attempting linux kill of makemkvcon
00:32:58 T:139637463594752 NOTICE: [BR-makemkvinteraction 1] Linux call successful
00:32:58 T:139637463594752 NOTICE: [BR-makemkvinteraction 1] temporary file with disc info: /tmp/tmpW2qCSh
00:32:58 T:139637463594752 NOTICE: [BR-makemkvinteraction 1] Return code for disc info generation: 0
00:32:58 T:139637463594752 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xd0 in position 0: ordinal not in range(128)
File "/home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/default.py", line 194, in <module>
mydisplay.handleListing()
File "/home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/default.py", line 88, in handleListing
self.CATEGORIES()
File "/home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/default.py", line 153, in CATEGORIES
self.addDir(_(50061) %(disc[0], disc[1]),1, True, disc[0], disc[1])
UnicodeDecodeError: 'ascii' codec can't decode byte 0xd0 in position 0: ordinal not in range(128)
00:32:58 T:139638365935552 ERROR: GetDirectory - Error getting plugin://plugin.makemkvbluray/
00:32:58 T:139638365935552 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.makemkvbluray/) failed
00:32:58 T:139637463594752 NOTICE: Thread BackgroundLoader start, auto delete: false
I have problem
Kodibuntu - 15.2
log:
self.CATEGORIES()
2015-12-24, 04:39
It has been mentioned in this thread but this addons is not needed anymore:
http://forum.kodi.tv/showthread.php?tid=173474
Do not followed makemkv instructions or it will break you Kodi install. Somebody gave some better instructions: http://forum.kodi.tv/showthread.php?tid=...pid1551341
If you have a good install of makemkv with the proper key and followed these instructions, it will work.
I am also able to get to work with the play disc command.
2015-12-24, 23:19
Hello, SamBotte
Ok.
I do not have a file "libaacs.so"
Thanks !
Ok.
Quote:If you have a good install of makemkv with the proper keyHow to properly install makemkv on Ubuntu?
Thanks !
2015-12-27, 19:21
1. wget "http://www.makemkv.com/download/makemkv-bin-1.9.8.tar.gz"
2. sudo apt-get install build-essential pkg-config libc6-dev libssl-dev libexpat1-dev libavcodec-dev libgl1-mesa-dev libqt4-dev
3. unpack makemkv-bin
4. cd /dir/who/makemkv-bin
5. make
sudo make install
6. touch ~/.MakeMKV/settings.conf and insert
app_Key = "<the key goes here>" (put the key between the quotation marks) .
key --> http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
5. make
sudo make install
2016-03-07, 17:16
KODI v16
Install adoon: https://github.com/X-dark/plugin.makemkv.../1.1.3.zip
ERROR
LOG:
ERROR
LOG:
18:10:23 T:140115765815296 DEBUG: Activating window ID: 10025
18:10:23 T:140115765815296 DEBUG: ------ Window Deinit (DialogAddonInfo.xml) ------
18:10:23 T:140115765815296 DEBUG: ------ Window Deinit (AddonBrowser.xml) ------
18:10:23 T:140115765815296 DEBUG: ------ Window Init (MyVideoNav.xml) ------
18:10:23 T:140115765815296 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.makemkvbluray/)
18:10:23 T:140115765815296 DEBUG: ParentPath = [plugin://plugin.makemkvbluray/]
18:10:23 T:140115765815296 DEBUG: StartScript - calling plugin BluRay Player with MakeMKV('plugin://plugin.makemkvbluray/','1','')
18:10:23 T:140115765815296 DEBUG: WaitOnScriptResult - waiting on the BluRay Player with MakeMKV (id=3) plugin...
18:10:23 T:140114785203968 DEBUG: Thread LanguageInvoker start, auto delete: false
18:10:23 T:140114785203968 INFO: initializing python engine.
18:10:23 T:140114785203968 DEBUG: CPythonInvoker(3, /home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/default.py): start processing
18:10:23 T:140114785203968 DEBUG: -->Python Interpreter Initialized<--
18:10:23 T:140114785203968 DEBUG: CPythonInvoker(3, /home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/default.py): the source file to load is "/home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/default.py"
18:10:23 T:140114785203968 DEBUG: CPythonInvoker(3, /home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/default.py): setting the Python path to /home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
18:10:23 T:140114785203968 DEBUG: CPythonInvoker(3, /home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/default.py): entering source directory /home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3
18:10:23 T:140114785203968 DEBUG: CPythonInvoker(3, /home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/default.py): instantiating addon using automatically obtained id of "plugin.makemkvbluray" dependent on version 2.1.0 of the xbmc.python api
18:10:23 T:140114785203968 DEBUG: [BR 1] Starting the BluRay script
18:10:23 T:140114785203968 DEBUG: [BR 1] args
18:10:23 T:140114785203968 DEBUG: [BR 1] plugin://plugin.makemkvbluray/
18:10:23 T:140114785203968 DEBUG: [BR 1] 1
18:10:23 T:140114785203968 DEBUG: [BR 1] done args
18:10:23 T:140114785203968 DEBUG: [BR 1] Staring
18:10:23 T:140114785203968 DEBUG: [BR-settings 1] reading settings
18:10:23 T:140114785203968 DEBUG: [BR-settings 1] raw param string:
18:10:23 T:140114785203968 DEBUG: [BR 1] mode: None
18:10:23 T:140114785203968 DEBUG: [BR 1] Showing categories
18:10:23 T:140114785203968 DEBUG: [BR-makemkvinteraction 1] attempting linux kill of makemkvcon
18:10:23 T:140114785203968 DEBUG: [BR-makemkvinteraction 1] Linux call successful
18:10:23 T:140114785203968 DEBUG: [BR-makemkvinteraction 1] temporary file with disc info: /tmp/tmpHr0IQc
18:10:26 T:140115765815296 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0
18:10:26 T:140115765815296 DEBUG: OnKey: return (0xf00d) pressed, action is Select
18:10:26 T:140115765815296 DEBUG: Activating window ID: 10000
18:10:26 T:140115765815296 DEBUG: ------ Window Init (Home.xml) ------
18:10:26 T:140114785203968 DEBUG: [BR-makemkvinteraction 1] Return code for disc info generation: 0
18:10:26 T:140114785203968 DEBUG: LocalizeStrings: no translation available in currently set gui language, at path /home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/resources/language/Russian
18:10:26 T:140114785203968 DEBUG: LocalizeStrings: no strings.po file exist at /home/igora100/.kodi/addons/plugin.makemkvbluray-1.1.3/resources/language/english, fallback to strings.xml
18:10:26 T:140114785203968 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
self.CATEGORIES()
18:10:26 T:140114785203968 INFO: Python script stopped
18:10:26 T:140114785203968 DEBUG: Thread LanguageInvoker 140114785203968 terminating
18:10:26 T:140115765815296 DEBUG: WaitOnScriptResult - plugin exited prematurely - terminating
18:10:26 T:140115765815296 ERROR: GetDirectory - Error getting plugin://plugin.makemkvbluray/
18:10:26 T:140115765815296 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.makemkvbluray/) failed
18:10:26 T:140115765815296 DEBUG: CGUIMediaWindow::GetDirectory ()
18:10:26 T:140115765815296 DEBUG: ParentPath = [plugin://plugin.makemkvbluray/]
18:10:26 T:140114785203968 DEBUG: Thread BackgroundLoader start, auto delete: false
18:10:26 T:140114785203968 DEBUG: Thread BackgroundLoader 140114785203968 terminating
18:10:26 T:140115765815296 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
18:10:32 T:140115765815296 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
18:10:34 T:140114868279040 DEBUG: Thread JobWorker 140114868279040 terminating (autodelete)
18:10:34 T:140115765815296 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-x86_64-linux.so)
2016-03-09, 19:30
Guys,
I tried to install from ZIP the 'plugin.makemkvbluray.zip' but I got an error message saying that "dependency xbmc.python v1.0 could not be met".
I have MakeMkv working but I now I want to be able to watch Blu-Ray on my Kodi 16.0 (Jarvis).
Any help is appreciated.
2016-08-14, 21:15
Does this work in v17?
2017-08-25, 22:10
From LibreELEC forum.
https://forum.libreelec.tv/thread/499-so...#post60275
2019-10-20, 11:53
(2010-01-15, 16:20)magnetism Wrote: [ -> ]please tell me these files need to be downloaded to the update folder on the device?coreelecc system on usb
2019-10-20, 12:17
(2010-01-15, 16:20)magnetism Wrote: [ -> ][font][font]Теперь также доступно в виде дополнения [/font][/font]
[font][font]http://www.bultsblog.com/plugin.makemkvbluray.zip[/font][/font]
[font][font]Установка из zip. [/font][font]Выполните все другие шаги, чтобы получить makemkv и т. Д. [/font][/font]
[font][font]=========== [/font][/font]
[font][font]Я обновляю этот первый пост в качестве заполнителя для текущего состояния разработки плагина. [/font][font]Исходный сценарий, который я сейчас забросил в качестве платформы разработки, я буду держать местоположение сценария некоторое время, пока мы не узнаем, что плагин полностью функционален.[/font][/font]
[font][font]Хорошо, теперь для нового: я выпустил версию видео-плагина BluRay. [/font][font]Пожалуйста, имейте в виду, что это все еще версия для разработки. [/font][font]Я тестировал так же хорошо, как и на Vista, и проигрывал диск на Linux, так что мне вполне комфортно, что он будет работать. [/font][font]Однако, пока вы не проверите себя, я настоятельно рекомендую вам сохранить копию оригинального сценария, чтобы вы могли вернуться к этому. [/font][/font]
[font][font]Если у вас есть какие-либо отзывы, предложения или сообщения об ошибках, пожалуйста, используйте эту ветку, чтобы мы все могли поделиться, спасибо! [/font][/font]
[font][font]Требования [/font][/font]
[font][font]* Рабочая установка MakeMKV. [/font][font]Если вы устанавливаете под Linux, убедитесь, что вы установили и исходный код, и бинарный пакет, иначе утилита командной строки не будет там. [/font][/font]
[font][font]* Источник BluRay, либо диск, либо iso, либо что-то в этом роде. (Какой смысл в другом ...)[/font][/font]
[font][font]Установите плагин [/font][/font]
[font][font]* Загрузите текущую версию плагина [/font][/font][font][font]здесь[/font][/font]
[font][font]* Распакуйте / Установите плагин в свой плагин / путь к видео, чтобы он действовал как плагин для видео [/font][/font]
[font][font]Используйте плагин [/font][/font]
[font][font]Просмотрите ваши видео плагины и, если все прошло успешно с установкой BluRay Плагин теперь должен быть выбран. [/font][font]Введите его и играйте в BluRay. Изначально есть 3 варианта источника и выбор, чтобы перейти к настройкам плагина. [/font][font]Варианты источника: [/font][/font]
[font][font]* Диск, воспроизведение диска, вставленного в дисковод BluRay (также может быть DVD, если вы действительно хотите ...)[/font][/font]
[font][font]* Расположение файлов, найдите расположение файлов в источниках видео и используйте его в качестве источника BluRay. [/font][font]Выбор может быть либо ISO-образом, либо файлом index.bdmv, если каталог был извлечен. [/font][font]Примечание. Поскольку фактическая потоковая передача изображения делегирована исполняемому файлу makemkvcon, можно использовать только файлы, доступные на уровне файловой системы. [/font][font]Если вы использовали выбранный XBMC источник samba, iso-файлы из этого расположения не будут работать. [/font][/font]
[font][font]* Удаленный, вы можете позволить ему подключаться к удаленной машине с настройкой потока уже.[/font][/font]
[font][font]Все три варианта источника имеют выбор «play» и «browse». [/font][font]Если вы выберете «воспроизведение», плагин автоматически определит наиболее продолжительную функцию на диске и начнет ее воспроизведение. [/font][font]Удобно, если у bluray есть только одна главная особенность (например, фильмы). [/font][font]Если вы выберете «Обзор», плагин будет отображать подборку глав на диске и позволит вам выбрать ту, которую вы хотите воспроизвести. [/font][font]Удобно, если вы смотрите сериал BluRay с несколькими эпизодами. [/font][/font]
[font][font]К сожалению, при просмотре выбора в потоках не так много информации. [/font][font]Это потому, что стример MakeMKV, к сожалению, больше не предоставляет никакой информации. [/font][/font]
[font][font]Объяснение настроек: [/font][/font]
[font][font]Настройки разделены на три раздела [/font][/font]
[font][font]* Общие настройки[/font][/font]
[font][font]o MakeMKV местоположение. [/font][font]-> Укажите ваш исполняемый файл makemkvcon. [/font][font]Если он находится на вашем пути, по умолчанию все должно быть в порядке, в противном случае просто перейдите к правильному местоположению и выберите его. [/font][/font]
[font][font]o Секунды ожидания потока -> Сообщите сценарию, как долго он должен ждать, пока makemkv завершит синтаксический анализ диска / iso, прежде чем вызвать его завершение и выход. [/font][font]По умолчанию 2 минуты. [/font][/font]
[font][font]o Локальный номер порта -> При локальном запуске makemkvcon это номер порта, который будет прослушивать скрипт. [/font][font]По умолчанию все должно быть в порядке [/font][/font]
[font][font]* Параметры просмотра [/font][/font]
[font][font]o Включить поддержку диска -> Включить или отключить поддержку диска [/font][/font]
[font][font]o Включить поддержку расположения файла -> Включить или отключить поддержку просмотра ISO и структуры каталогов для воспроизведения [/font][/font]
[font][font]o Включить поддержку удаленного расположения -> Включить или отключена поддержка потоковой передачи из удаленного местоположения[/font][/font]
[font][font]* Удаленная настройка [/font][/font]
[font][font]Этот раздел отображается только в том случае, если вы включили поддержку удаленного расположения. [/font][font]Введите IP-адрес и номер порта удаленного расположения потока makemkv. [/font][/font]
[font][font]История изменений [/font][/font]
[font][font]0.1a [/font][/font]
[font][font]* Исправлена [/font][font]ошибка [/font][font]кода с обработкой исключений, [/font][font]приводившая к «забыванию» [/font][font]реальной ошибки [/font][/font]
[font][font]* Исправлена проблема с кодом регистрации, который препятствовал потоковой передаче дисков (упс, уже!) [/font][/font]
[font][font]0.1 [/font][/font]
[font][font]* Первоначальный выпуск плагина на основе кода сценария, который имеет больше, чем раньше [/font][/font]
[font][font]* Выбор основных функций теперь стал более «интеллектуальным» благодаря выбору самого длинного потока. [/font][/font]
[font][font]* Изменены настройки, чтобы сделать их более понятными, позволив категориям источников [/font][/font]
[font][font]===== СТАРЫЙ сценарий: [/font][/font]
[font][font]Местоположение для получения старого сценария: [/font][/font][font][font]http: //www.bultsblog. ком / BluRay-script.zip[/font][/font]
[font][font]==== СЛЕДУЮЩАЯ первая запись начинается здесь [/font][/font]
[font][font]Только на голову, что мне удалось воспроизвести оригинальный диск Blu-Ray в приводе Blu-ray с использованием XBMC. [/font][font]Это не так удобно для пользователя, как могло бы быть, но, по крайней мере, теперь это возможно. [/font][/font]
[font][font]Шаги: [/font][/font]
[font][font]- Установите MakeMKV [/font][/font]
[font][font]- Вставьте Blu ray [/font][/font]
[font][font]- Потоковый диск makemkvcon: 0 [/font][/font]
[font][font]- [/font][font]Найдите [/font][font]где-нибудь браузер и укажите его:[/font][/font]
[font][font]Предполагая, конечно, что вы xbmc по этому IP. [/font][/font]Code:[font][font]http://192.168.0.103:8080/xbmcCmds/xbmcHttp?command=PlayFile(http://192.168.0.103:51000/stream/title0.m2ts;1)[/font][/font]
[font][font]- Смотреть фильм .... [/font][/font]
[font][font]Вы можете просмотреть индекс Blu Ray, указывая на [/font][/font][font][font]http://192.168.0.103:51000/[/font][/font][font][font] Кстати. [/font][/font]
[font][font]Теперь, чтобы выяснить, как добавить это в плагин ... [/font][/font]
[font][font]Я прошу прощения, если это уже было широко известно, но это было для меня новым.[/font][/font]
2019-10-20, 12:36
@[email protected] - please review your last few posts. They are in Russian and stuffed full of [font] tags.
The board language is English only, and I guess you are or some other posting service which does not work properly with our forum software.
Currently your posts are unreadable and so we cannot offer any support from them.
2022-09-03, 22:16
Will this work with nvidia shield tv pro 2019 and kodi 19.4? Or wrong section of forum?
I have a spare usb 3 port on the shield available and a LG BU40N.
