2010-01-15, 23:14
2010-01-15, 23:17
Code it into a current skin or an entirely new one?
2010-01-15, 23:20
I'm a newbee, so what do you think is best?
gr
chester
gr
chester
2010-01-16, 19:08
chesterpro2010 Wrote:I'm a newbee, so what do you think is best?If you have a favourite skin, and you are happy with that skin, you should include your view in this skin.
gr
chester
If you have more ideas that you want to see in a skin, then you can make an own skin (but that is a lot of work)
ps. this info looks realy nice
2010-01-17, 02:28
thnx
so i can implement it in my favourite skin, i tried to find the png files used in the the texture.xml, but i couldn't find the locations in other xml files.
example: i'd like to mod is the showcase view (Aeon Hitched). Where do i find the scripting for the position and measurements for a png in a xml file?
Gr.
Chester
Gr.
Chester
2010-01-17, 02:58
In the 720 folder, Viewtype_Showcase.xml... Aeon is tough code to follow, but you learn by doing.
2010-01-17, 03:03
Thnx
Taking a look at it right now
Gr
Chester
Gr
Chester
2010-01-17, 03:10
One little tip that helps in learning is take a block of code like so:
Delete from <control> to </control>, save and refresh the skin is a simple way to find out what does what.
Quote:<control type="textbox"><!-- Plot TV -->
<visible>Control.IsVisible(50) + Container.Content(tvshows)</visible>
<posx>20</posx>
<posy>260</posy>
<width>350</width>
<height>308</height>
<align>left</align>
<info>ListItem.Plot</info>
<font>Font_Bartowski_Movies_Plot</font>
<textcolor>ffffffff</textcolor>
</control>
2010-01-17, 03:20
Thnx
I'm gonna make a replica in my skin folder.
The control types stands for all the image positions and measurements?
So i can make setup for a view
2010-01-17, 03:26
Cotrol type image, textbox .......
I get the idea
gr chester
I get the idea
gr chester
