Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
grey Wrote:have a question:
if i update to a current svn build and the playback becomes choppy, can i downgrade to a build which was working satifsactory?
save out the current one (manually) by moving it.
mv Applications/XBMC Applications/XBMC_saved
davilla, unfortunately this command gives me error. on appletv i don't have such a folder.
in Applications all i have is XBMC.app
Applications/XBMC.app is the correct path
when i am watching hd content on the crystalhd enabled atv it works like a charm.
after some minutes it starts lagging like hell. atv cpu is at around 20% load.
Pasebin
Complete name : FOLDER.mkv
Format : Matroska
File size : 1.09 GiB
Duration : 41mn 51s
Overall bit rate : 3 738 Kbps
Encoded date : UTC 2010-01-30 04:12:28
Writing application : mkvmerge v2.0.2 ('You're My Flame') built on Jul 16 2008 20:03:58
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container [email protected]
Codec ID : V_MPEG4/ISO/AVC
Duration : 41mn 48s
Bit rate : 3 279 Kbps
Nominal bit rate : 3 351 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.148
Stream size : 981 MiB (88%)
Writing library : x264 core 68 r1184tw
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=240 / keyint_min=24 / scenecut=40 / rc=2pass / bitrate=3351 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 41mn 51s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 115 MiB (10%)
when it shutters i get the following in xbmc.log
13:00:52 T:52622848 M: 10432512 DEBUG: CrystalHD: SetDropState... 0
13:00:52 T:52622848 M: 10432512 DEBUG: CrystalHD: SetDropState... 1
13:00:52 T:52622848 M: 10641408 DEBUG: CrystalHD: SetDropState... 0
i have seen this error before on this forum. maybe we can find out what is wrong.
-andy
xbmc info: Starting XBMC, Platform: Mac OS X. Built on Jan 29 2010 (SVN:27265)
i am trying to play the movie over nfs and gigabit fileserver. fileserver is a fedora based core2duo machine, doing over 80 MB/sec.
currently i copy the file to atv local disk and try again.
-andy
local playing makes no difference
I'm seeing the same issue as Andy on r27265. Playback is excellent for a good 10 minutes or so then it'll get choppy for a bit and then start playing good again. I'm using passthrough digital audio, so no audio decode to slow it down. I also see the same 'SetDropState' message in the logs.
I'm hoping to get to the point that we can watch 720p mkv videos flawlessly
Thanks for all the support.
I think we just need to continue to be patient. This is a known issue and as Davilla has said, his time to work on this is limited. This weekend alone there's been 7 commits to SVN surrounding CrystalHD support.
Give the guy some time to get things sorted
i dont want to press someone
i just wanted to post some logs and maybe it can help the developers.
-andy
Just a side note:
You can always rollback to a revision that works perfectly with 720p. Yesterday I did an update to latest SVN version compiled, then bumped into the same issue as reported here for the ATV.
TeknoJnky did an excellent job with revision installer here:
http://forum.xbmc.org/showthread.php?tid...ght=script
Just pick rev26651. Life is good again
rev26651 works like a charm. thanks for that info!
so you're saying that rev26651 does not suffer from this slow'mo problems?
wrong alert. suffers aber 20 minutes, instead after some minutes. doesnt work neither!
... so still 3 times better experience than with recent svn.
So just wait and hope chief Davilla will fix the recent bug soon.
having big troubles playing new LOST episode...
video stats:
Video: AVC at 3 195 Kbps, 1280 x 720 (1.778) at 23.976 fps
Audio: AC-3 at 384 Kbps, 6 channels, 48.0 KHz
