Hi, Ive recently been running into this error message when running XBMC on my Apple TV - xbmc/boxee exited with status: 5. I've seen other people report similar errors but with different numbers. I've not been able to find any info on the #5 error. It happens when I try to play DVDs that I've ripped using RipIt on my mac. They have played successfully numerous times but are now crashing XBMC when I try to play them.
Anyone with information and support would be appreciated.
I usually get the number 10 or 11 error. Have only had XBMC on my atv for 3 days now so dont know if this is normal or not.
I have no problem playing them on Boxee or Nito TV. As i mentioned, I have actually played them on XBMC before with no problems, but tried to finish watching a movie last night and when I did, I get the exited with status: 5.
Same here.. Plays well in NitoTV, Boxee and Sapphire.. Dont think its a movie problem. There is something within XBMC. I have other issues than this but thats in my other thread.
Hey jlowpool,
welcome to this forum.
Please check
this link about posting about a problem in a useful manner, especially parts about xbmc.log, crashreporter.log and console.log
cheers,
mdd
MaestroDD Wrote:Hey jlowpool,
Please check this link about posting about a problem in a useful manner, especially parts about xbmc.log, crashreporter.log and console.log
cheers,
mdd
Thanks, I'll get the information posted shortly. I appreciate your help!
jooz Wrote:I usually get the number 10 or 11 error. Have only had XBMC on my atv for 3 days now so dont know if this is normal or not.
Do you have XBMC power saving features enabled? I seem to get this error if Power Saving (auto-exit) is enabled.
OSX Version 10.5.8
Platform - AppleTV
Launcher 3.2.2
Install Method - Launcher
SVN Revision - XBMC PRE-10.5 r26936 (Compiled: Jan 17 2010)
Detailed Instructions to Reproduce the Problem - In the VIDEOS menu, when I select a movie from the file list and select the IFO file to start playing the movie (these are movies that I have used RipIt to copy onto a Western Digital HD that is connected to my Apple TV) it crashes and shows this error message: xbmc/boxee exited with status: 5.
http://pastebin.com/m742f40d4
Thanks in advance for any help, and if I have forgotten anything, let me know and I will get that information posted as well.
Thanks,
jamie
Hey jlowpool,
thanks for posting the detailed information.
Mind posting crashreporter.log, too?
Will do! It will be later tonight before I will be back home, but I will get it posted as soon as I can.
Thanks,
Jamie
jlowpool Wrote:Here is the CrashReporter.log:
http://pastebin.com/mf4979ec
Thanks for the update.
Relevant part is:
Quote:Command: XBMC
Path: /Applications/XBMC.app/Contents/MacOS/XBMC
Parent: Finder [124]
Version: 9.11.alpha2 (SVN-26936)
PID: 196
Thread: Unknown
Link (dyld) error:
Symbol not found: ___eprintf
Referenced from: /mnt/Scratch/Users/frontrow/Applications/XBMC.app/Contents/Resources/XBMC/system/players/dvdplayer/libdvdnav-x86-osx.so
Expected in: flat namespace
Not sure where this comes from, but someone will look into it....
Thanks again for your help!
Jamie
should be fixed with
r27031.
Mind reporting back once a build >27031 appears?
Thanks,
mdd
