Hi
is this
fix already in the xbmc trunk version
r26903.
I use the RecentlyAdded.py script from Nuka on the Homepage, if i join the shutdownmenu (key "s") the images/icons of recent movies disappear and only the fallback is visible.
thanks, eumel
I should think that the property should be read first and foremost from the window that they reside in. Will take a look.
Ok, only happens for properties being used inside a list.
r26925 should do the trick.
jmarshall Wrote:r26925 should do the trick.
many thanks jm, will test it with the next nightly build
