Full Version: Problem with Update library vs Scan for new content (logs provided)?
For some reason update library is not working for me on my TV shows since my initial scan, instead I have to use a scan for new content on the TV show itself for it to pick up any new episodes. I cant figure out at all why it wouldnt be picking up the episodes in the update library because it is definately scanning the folder.
You can clearly see the difference in the debug log between the 2 scans of the same folder: http://pastebin.com/m438b2109
Anyone have any ideas?
do you have recursive scanning enabled?
Selecting "scan for new content" should be enough - even if your series are in subfolders.
Yes, recursive scanning is enabled. I havent tried scan for new content at a higher level than the series but it does work at that level. Update Library doesnt.
