I've been troubleshooting a couple wake from suspend issues since upgrading to 9.11 final and there is one that is baffling me. I added 'echo US15 > /proc/acpi/wakeup' to rc.local so that it would set that at each boot, but it doesn't. If I manually run 'echo US15 > /proc/acpi/wakeup', US15 shows as enabled when I run 'cat /proc/acpi/wakeup'. But after a reboot everything shows as disabled. Here is my rc.local:
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
exit 0
Any ideas why that could be?
Try using the "tee" command. I added the following to my rc.local:
echo "USB0" | sudo tee /proc/acpi/wakeup
Replace USB0 with US15 in your case.
what does tee on a single file do? The tee command is usually used to port a single output to multiple outputs. what does it do when it is used as a single output?
I'm not sure it's the tee that's helping... I think it's the sudo.
I use:-
sudo sh -c 'echo USB0 > /proc/acpi/wakeup'
SweetS2K Wrote:Replace USB0 with US15 in your case.
Maybe that's why it's not working? Perhaps it should be USB15, not US15?
Post your cat /proc/acpi/wakeup
decaturguy Wrote:Post your cat /proc/acpi/wakeup
Here it is after a reboot:
root@XBMCLive:~# cat /proc/acpi/wakeup
Device S-state Status Sysfs node
PS2K S4 disabled pnp:00:09
UAR1 S4 disabled pnp:00:0c
SMB0 S4 disabled pci:0000:00:03.2
USB0 S4 disabled pci:0000:00:04.0
USB2 S4 disabled pci:0000:00:04.1
US15 S4 disabled pci:0000:00:06.0
US12 S4 disabled pci:0000:00:06.1
NMAC S5 disabled pci:0000:00:0a.0
PBB0 S4 disabled pci:0000:00:09.0
HDAC S4 disabled pci:0000:00:08.0
XVR0 S4 disabled pci:0000:00:0c.0
XVR1 S4 disabled
P0P5 S4 disabled
P0P6 S4 disabled pci:0000:00:15.0
P0P7 S4 disabled pci:0000:00:16.0
P0P8 S4 disabled
P0P9 S4 disabled
here it is after I manually type
echo US15 > /proc/acpi/wakeup:
root@XBMCLive:~# echo US15 > /proc/acpi/wakeup
US15 S4 enabled pci:0000:00:06.0
XVR1 S4 disabled
P0P5 S4 disabled
P0P8 S4 disabled
P0P9 S4 disabled
I had this setup and working in beta 2 without any extra commands. Not sure what's changed.
Try
sudo sh -c 'echo US15 > /proc/acpi/wakeup'
in your local.rc. I'm not sure you can modify wakeup without admin access.
J
Still no joy.
cat /proc/acpi/wakeup still shows all devices diasbled. Just to double check, here is my rc.local now:
sudo sh -c echo US15 > /proc/acpi/wakeup
exit 0
RockDawg Wrote:Still no joy. cat /proc/acpi/wakeup still shows all devices diasbled. Just to double check, here is my rc.local now:
exit 0
Forgot the single quote before echo and after wakeup.
nugentgl Wrote:Forgot the single quote before echo and after wakeup.
Indeed I did. Nonetheless, adding them didn't change anything. Is it possible rc.local isn't being run on boot up? Is there a way to manually run it? I tried the usual way, but it doesn't work:
root@XBMCLive:/etc# rc.local
-bash: rc.local: command not found
Is there a way to tell if rc.local is being run at boot time?
You could have it create a new file in your home directory to see if it is running. Something like:
touch /home/[user]/test.txt
If test.txt is in your home dir, then it is running. Then the next step would be to determine why your echo command is not working.
One other thing - have you sudo'd before?
If not try the sudo sh -c... blah blah blah at the command prompt when logged in as the user you gave to the Live installer when you installed xbmc. You may get prompted for your password again - if that user hasn't used sudo before. If that happens, type the password, check the proc/acpi/wakeup, reboot and see how it looks then.
nugentgl Wrote:You could have it create a new file in your home directory to see if it is running. Something like:
That's a good idea. I should've thought of that.
I tried it and test.txt was not created, so it seems as though rc.local is not executing.
touch /home/test.txt
exit 0
I should add that I tried your test on my other pc running XBMC Live that seems to be processing the rc.local file and it didn't create the test file either. And I tried with and without sudo.
