Full Version: Song info during Slideshow?
Hello everyone, I've searched the forum and can't find a solution so I hoping this is not a repeat post.
Running 9.11 on a Revo 3610 Live install to a SD card.
Problem I'm having, if I play an album and then start off a slideshow in pictures the song info is displayed all the time in the bottom left, I want to know if its possible for this info to de displayed for say 10 seconds per song, then disappear if not an it be disabled all together for slideshow.
I've found this command in advanced settings <songinfoduration>10</songinfoduration>
but i think its for visualisations only.
Any suggestions ?
Cheers
Chris
OK used the setting above in advanced settings and now the song info is not listed at all, this is better as I can avoid screen burn now. If anyone knows the correct fix for this I would appreciate it.
