2010-01-18, 21:33
2010-01-18, 22:56
gfrobe Wrote:I've found a few alternatives that I'd like to use but can't figure out how to change the actual photo. Can anyone help?
This is likely a skin related question. You will likely find your answer in the section dedicated to the skin you are using.
2010-01-19, 00:50
Thanks. Your reply gave me the clue to search through the skin files and I found the "music" jpg there. Thanks!
2010-01-22, 18:33
If you are using Confluence (I assume you are) there is a place in the System -> Settings that allows you to change any of the default pictures with just a couple clicks. You just browse to the picture you want and choose it and the Guitar will be replaced.
I changed the default 'Movies' and 'TV Shows' pictures so they would be different.
I like the Guitar so left that one.
