2010-01-19, 00:26
Hello,
I have noticed that multichannel audio doesn't follow the core audio layout. It is played following the layout of the audio file, a file with a C,L,R,SL,SR,Lfe configuration plays the center channel through the first track stream of the audio card although I have the core audio set to play center channel through track 3. So the file won't match my speakers configuration if the channels layout of the file is different.
Is there any way to get this working correctly or it's a bug that need fixing?
Thank you.
Thank you.
