Full Version: No sound while using the video plugins
I'm on Karmic 64-bit and using XBMC SVN rev 27006. I and running HDMI audio out, and have no problems with audio during (local) video playback, and the GUI sounds come through fine. I only lose sound when I try to play a video over any of the plugins. I used the Mythbusters plugin to create this log.
Here are some possibly relevant lines from the log. Keep in mind that the video plays correctly.
WARNING: OpenVideoStream - Unsupported stream 0. Stream disabled.
01:14:04 T:139831309981968 M:973541376  NOTICE: Opening audio stream: 1 source: 256
01:14:04 T:139831309981968 M:973541376  NOTICE: Finding audio codec for: 0
01:14:04 T:139831309981968 M:973541376   DEBUG: FactoryCodec - Audio: passthrough - Opening
01:14:04 T:139831309981968 M:973541376   DEBUG: FactoryCodec - Audio: passthrough - Failed
01:14:04 T:139831309981968 M:973541376   DEBUG: FactoryCodec - Audio: FFmpeg - Opening
01:14:04 T:139831309981968 M:973541376   DEBUG: CDVDAudioCodecFFmpeg::Open() Unable to find codec 0
01:14:04 T:139831309981968 M:973541376   DEBUG: FactoryCodec - Audio: FFmpeg - Failed
01:14:04 T:139831309981968 M:973541376   ERROR: Unsupported audio codec
01:14:04 T:139831309981968 M:973541376 WARNING: OpenAudioStream - Unsupported stream 1. Stream disabled.
DEBUG: RemoveActiveDevice - Removing device 1
01:14:04 T:139831862007856 M:973541376   DEBUG: OnPlayBackStarted - Playback has started
01:14:04 T:139831518689552 M:973541376   DEBUG: CGUIAudioManager::DeInitialize
01:14:04 T:139831518689552 M:973541376   DEBUG: SetActiveDevice - SetActiveDevice from 0 to 2
01:14:04 T:139831518689552 M:973541376   DEBUG: RemoveActiveDevice - Removing device 0
01:14:04 T:139831862007856 M:973541376  NOTICE: Using GL_TEXTURE_2D
01:14:04 T:139831862007856 M:973541376   DEBUG: GL: Requested render method: 4
01:14:04 T:139831518689552 M:973541376   DEBUG: Initialize - using alsa device plug:hdmi
01:14:04 T:139831862007856 M:973541376  NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
01:14:04 T:139831862007856 M:973541376   DEBUG: GL: Shader compilation log:
01:14:04 T:139831518689552 M:973541376   DEBUG: CALSADirectSound::Initialize - packet size:2048, packet count:16, buffer size:8192
Full log here:
http://pastebin.com/m25ec380f
