I am running ATV 3.01 and Launcher 3.2.2 . Not interested in Boxee and I don't like looking at the entry
Is there a way of hiding or deleting it from the Menu so that I only see XBMC, Downloads, etc...?
Thank's,
philip
good question, I'm also interested in the answer.
also,
how can I remove (or fix) the non-functional software menu?
how can I make the xbmc menu the first before movies/tvs on the launcher?
TeknoJnky Wrote:good question, I'm also interested in the answer.
also,
You can ssh into the ATV. Then go
cd /System/Library/CoreServices/Finder.app/Contents/PlugIns
ls
sudo -S mount -uw /
sudo rm -R SoftwareMenu.frappliance
sudo mount -ur /
The ls is just to be sure where you are. The mount at the end is to make the system read only ( which is the safer default).
philip
Edit: Upgrade software menu to the latest beta. It is functional.
Not to highjack the thread, but since it was mentioned.
Can I install the beta software menu? I didn't choose that option on initial install because I knew it wasn't working at all. Since there's a working beta, I'd like to add a Software Menu now.
pmcd Wrote:I am running ATV 3.01 and Launcher 3.2.2 . Not interested in Boxee and I don't like looking at the entry Is there a way of hiding or deleting it from the Menu so that I only see XBMC, Downloads, etc...?
Thank's,
philip
yes, edit Info.plist in XBMCLauncher.frappliance and remove Boxee entry.
be sure to backup first
Zeljko
