I have been adding my tv seasons to xbmc and am having trouble with SharkWeek. The first disk was succesfully scraped and episode information was entered correctly, the first episode on the second disk had information found and none of the other two disks has information found..I can manually enter in the titles of the episodes but they dont go to the right library they are placed with my movies as aposed to tv series. Can anyone help with this problem?
excuse my ignorance thankyou for your time i beleive this is what you are asking for
19:34:32 T:3046319984 M:3201953792 ERROR: Failed to create common scripts symlink.
19:34:32 T:3046319984 M:3201953792 NOTICE: -----------------------------------------------------------------------
19:34:32 T:3046319984 M:3201953792 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Dec 24 2009 (SVN:26018)
19:34:32 T:3046319984 M:3201953792 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
19:34:32 T:3046319984 M:3201953792 NOTICE: special://masterprofile/ is mapped to: /home/mcleod/.xbmc/userdata
19:34:32 T:3046319984 M:3201953792 NOTICE: special://home/ is mapped to: /home/mcleod/.xbmc
19:34:32 T:3046319984 M:3201953792 NOTICE: special://temp/ is mapped to: /home/mcleod/.xbmc/temp
19:34:32 T:3046319984 M:3201953792 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
19:34:32 T:3046319984 M:3201953792 NOTICE: Log File is located: /home/mcleod/.xbmc/temp/xbmc.log
19:34:32 T:3046319984 M:3201642496 NOTICE: Setup SDL
19:34:32 T:3046319984 M:3200765952 NOTICE: load settings...
19:34:32 T:3046319984 M:3200765952 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:34:32 T:3046319984 M:3200765952 NOTICE: loading special://masterprofile/guisettings.xml
19:34:32 T:3046319984 M:3200765952 NOTICE: Getting hardware information now...
19:34:32 T:3046319984 M:3200765952 NOTICE: Checking resolution 11
19:34:32 T:3046319984 M:3200790528 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:34:32 T:3046319984 M:3201048576 NOTICE: Loaded playercorefactory configuration
19:34:32 T:3046319984 M:3201048576 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:34:32 T:3046319984 M:3201048576 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:34:32 T:3046319984 M:3201048576 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
19:34:32 T:3046319984 M:3201048576 NOTICE: Default DVD Player: dvdplayer
19:34:32 T:3046319984 M:3201048576 NOTICE: Default Video Player: dvdplayer
19:34:32 T:3046319984 M:3201048576 NOTICE: Default Audio Player: paplayer
19:34:32 T:3046319984 M:3201048576 NOTICE: special://masterprofile/sources.xml
19:34:33 T:3046319984 M:3153141760 NOTICE: Using fbConfig[0]
19:34:33 T:3046319984 M:3151929344 NOTICE: GL_VENDOR = ATI Technologies Inc.
19:34:33 T:3046319984 M:3151929344 NOTICE: GL_RENDERER = ATI Radeon HD 4200
19:34:33 T:3046319984 M:3151929344 NOTICE: GL_VERSION = 2.1.9016
19:34:33 T:3046319984 M:3151929344 NOTICE: GL_EXTENSIONS = GL_AMD_draw_buffers_blend GL_AMD_performance_monitor GL_ARB_color_buffer_float GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_snorm GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_explicit_multisample GL_NV_primitive_restart GL_NV_texgen_reflection GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
19:34:33 T:3046319984 M:3150901248 NOTICE: DeviceKit.Disks: Added /media/mynewdrive
19:34:33 T:3046319984 M:3150266368 NOTICE: start dvd mediatype detection
19:34:33 T:3046319984 M:3150012416 NOTICE: initializing playlistplayer
19:34:33 T:3046319984 M:3150012416 NOTICE: DONE initializing playlistplayer
19:34:33 T:3046319984 M:3149250560 NOTICE: load default skin:[Confluence]
19:34:34 T:3046319984 M:3145940992 NOTICE: UpdateLibraries - Starting video library startup scan
19:34:34 T:3046319984 M:3146076160 NOTICE: initialize done
19:34:34 T:3046319984 M:3146076160 NOTICE: Running the application...
19:34:34 T:3046319984 M:3146076160 NOTICE: ES: Starting event server
19:34:34 T:3046319984 M:3146076160 NOTICE: DS: Starting dbus server
19:34:34 T:2865748848 M:3145687040 NOTICE: DS: Starting DBUS server in Run Application aka thread
19:34:34 T:3046319984 M:3145687040 NOTICE: starting zeroconf publishing
19:34:35 T:3046319984 M:3145216000 ERROR: GLX: Same window as before, refreshing context
19:34:35 T:2874141552 M:3145216000 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
19:34:35 T:2874141552 M:3145216000 NOTICE: UDP: Listening on port 9777
19:34:35 T:3046319984 M:3143970816 ERROR: GLX: Same window as before, refreshing context
19:34:41 T:2901154672 M:3136704512 ERROR: GetDirectory - Error getting /media/WestDig/MovieCollection/
19:34:41 T:2901154672 M:3136729088 ERROR: GetDirectory - Error getting /media/WestDig/TV Shows Collection/
19:34:41 T:2901154672 M:3136753664 ERROR: GetDirectory - Error getting /media/WestDig/TV Shows Collection/AfroSamurai/
19:34:43 T:2901154672 M:3135180800 ERROR: GetDirectory - Error getting /media/mynewdrive/MovieCollection/a/
19:34:43 T:2901154672 M:3133054976 NOTICE: My Videos: Scanning for video info using worker thread, operation took 00:08
19:34:52 T:3046319984 M:3122475008 WARNING: GetLabel - Unknown nodetype requested 12
19:35:25 T:3046319984 M:3124883456 NOTICE: Storing total System Uptime
19:35:25 T:3046319984 M:3124883456 NOTICE: Saving settings
19:35:25 T:3046319984 M:3124883456 NOTICE: stop all
19:35:25 T:3046319984 M:3124883456 NOTICE: ES: Stopping event server
19:35:25 T:3046319984 M:3124883456 NOTICE: stopping zeroconf publishing
19:35:25 T:2865748848 M:3122253824 NOTICE: DS: DBUS server stopped
19:35:25 T:2874141552 M:3122126848 NOTICE: ES: UDP Event server stopped
19:35:25 T:3046319984 M:3122126848 NOTICE: stop dvd detect media
19:35:25 T:3046319984 M:3122126848 NOTICE: stop sap announcement listener
19:35:25 T:3046319984 M:3122126848 NOTICE: clean cached files!
19:35:25 T:3046319984 M:3122126848 NOTICE: unload skin
19:35:26 T:3046319984 M:3125272576 NOTICE: stop python
19:35:26 T:3046319984 M:3125272576 NOTICE: stopped
19:35:26 T:3046319984 M:3125272576 NOTICE: destroy
19:35:26 T:3046319984 M:3125018624 NOTICE: unload sections
