Full Version: [WINDOWS] - Removing Confluence skin crashes XBMC - Not tested on Linux yet.
Hi Guys 'n Girlz
I am busy writing a skin and to test, I removed (renamed) the Confluence skin and only placed my skin in the directory.
XBMC for windows crashes on startup with:
The application has requested the Runtime to terminate in an unusual way.
(Please contact support...)
I have slao tested this on Linux yet and I believe this to be a bug...
Cheers
cybar7 (aka AubreyX)
ps - the WINDOWS log does not show anything strange, the last couple of lines read:
11:30:19 T:2772 M:1871101952 NOTICE: load settings...
11:30:19 T:2772 M:1871085568 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:30:19 T:2772 M:1871085568 NOTICE: loading special://masterprofile/guisettings.xml
11:30:19 T:2772 M:1870958592 NOTICE: Getting hardware information now...
11:30:19 T:2772 M:1870958592 NOTICE: Checking resolution 12
11:30:19 T:2772 M:1870946304 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:30:19 T:2772 M:1870938112 NOTICE: Loaded playercorefactory configuration
11:30:19 T:2772 M:1870934016 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:30:19 T:2772 M:1870934016 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:30:19 T:2772 M:1870934016 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
11:30:19 T:2772 M:1870934016 NOTICE: Default DVD Player: dvdplayer
11:30:19 T:2772 M:1870934016 NOTICE: Default Video Player: dvdplayer
11:30:19 T:2772 M:1870934016 NOTICE: Default Audio Player: paplayer
11:30:19 T:2772 M:1870929920 NOTICE: special://masterprofile/sources.xml
Confluence is the default skin XBMC looks for it on first run and if the current skin you are using it completly F.U.B.A.R.
If you have not set your skin to be used or have screwed up the code in your skin in anyway it will not have something good to fall back onto. which probably is causing your error
Yea no reason to delete the default skin, it's on 20mb or so...Always good to have as a backup and when troubling shooting issues Confluence should be the benchmark to use since as the default it has to be up to the standard that it should be error free.
