ok I have my acer 3610 and for some reason 720 and 1080 movies stutter the audio is off sync and the video is all jagged and moves slow. the cpu goes up to 160% total cpu and and just not working correctly. I have set the 512 to memory and also enabled vdpau as the render method.
I have the nvidia drivers 195.30
here is my
debug log
i started xbmc and played heroes in 720 and then starwars in 1080. both were horrible.
is VDPAU working? as I see the below in the log
23:19:33 T:2971650928 M:1149710336 NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1920x816)
23:19:33 T:2971650928 M:1149710336 NOTICE: (VDPAU) unable to get handle to libvdpau
23:19:33 T:2971650928 M:1149710336 NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
23:19:33 T:2971650928 M:1149710336 NOTICE: (VDPAU) ~CVDPAU
23:19:33 T:2971650928 M:1149710336 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
23:19:33 T:2971650928 M:1149710336 DEBUG: FactoryCodec - Video: ff-h264 - Opened
23:19:33 T:2971650928 M:1149710336 NOTICE: Creating video thread
23:19:33 T:2732579696 M:1149710336 DEBUG: thread start, auto delete: 0
Do i have to update my libvdpau? If so how?
ok I have tried the method of installing the below
sudo apt-get install nvidia-180-libvdpau
and now vdpau is enabled and working however my movies still stuttering and tearing.
settings are
Render Method = VDPAU
Adj Refresh = off
Sync playback = on
Allowed Error = None
VDPAU Studio level color conversion = off
any help?
what should I update in my xorg.conf
Device section
Section "Extensions"
Option "Composite" "Disable"
EndSection
Option "FlatPanelProperties" "Scaling=Native"
EndSection
also should I follow any of the steps in this
thread
this is frustrating as I thought xbmc 9.11 would work with the acer revo 3610 flawlessly on boht 720 and 1080 movies.
any help please
Ok my settings are:
Adj Refresh = on
Sync playback = off
VDPAU Studio level color conversion = on
if you have a 1080p supported monitor you could use a xorg.conf like this
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 15.0 - 68.0
VertRefresh 23.0 - 61.0
Option "DPMS"
Option "ExactModeTimingsDVI" "TRUE"
ModeLine "1920x1080@60" 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
ModeLine "1920x1080@50" 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
ModeLine "1920x1080@24" 74.16 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
Option "ModeValidation" "NoEdidModes"
Option "DynamicTwinView" "false" #twinview line
Option "UseEDIDFreqs" "False"
Option "HWCursor" "False"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
Option "Twinview" "0"
DefaultDepth 24
Option "DynamicTwinView" "False"
SubSection "Display"
Depth 24
Modes "1920x1080@60" "1920x1080@50" "1920x1080@24"
EndSubSection
EndSection
this will sync and auto switch to the correct Hz, but make sure you tv supports this or alter the modes, there are some guides here on the form to get the correct supported Modes of your tv
Meteorite Wrote:Ok my settings are:
Adj Refresh = on
Sync playback = off
Screen 0 "Screen0"
EndSection
Section "Files"
EndSection
Identifier "Mouse0"
Driver "mouse"
EndSection
Driver "kbd"
EndSection
EndSection
Section "Monitor"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Driver "nvidia"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
I am using a Panasonic PT-AX200U projector.
Video Compatibility: HDTV 1080p/60, 1080p/50, 1080p/24, 1080i, 720p, 576p, 576i, 480p. NTSC/PAL/SECAM.
I really doubt the 195.30 drivers work as expected with nvidia-180-libvdpau.
What's the output of
ls -l /usr/lib/libGL.so.* /usr/lib/vdpau/
You need to provide alot more info, at least a current debug log, for anyone be able to help. Please check the sticky
http://forum.xbmc.org/showthread.php?tid=34655
ok so I went into the nvidia gui and checked sync to vblank and checked allow flipping and that did something becuase its alot smoother playback and now the audio is not all off. the video is alot smoother now.
I still get tearing on the video however.
updated the below in the xorg.config and now its running smooth. playback in both 720 and 1080. audio sync is working, vdpau is working now and tearing is very minimal.
below is my xorg.config file
Section "Screen"
Identifier "Default Screen"
DefaultDepth 24
EndSection
Section "Module"
Load "glx"
EndSection
EndSection
Section "Device"
Identifier "Default Device"
Driver "nvidia"
Option "NoLogo" "True"
EndSection
anything that I need to add?
