Full Version: XBMC crash on startup?
Ok so I had XBMC working great before this newest version and then today I decide to upgrade and it's crashing almost immediately. Here is the crash log via pastebin.
http://ubuntu.pastebin.com/m4b5ac573
Any help greatly appreciated.
Nevermind, looks like I was missing a dependant package. For some reason the SVN build didn't auto select it but I just needed to install libcurl3.
Dougie085 Wrote:Nevermind, looks like I was missing a dependant package. For some reason the SVN build didn't auto select it but I just needed to install libcurl3.
Dougie,
I had the same problem when i upgraded. I am farely new to linux, but can you tell me what command you used to install libcurl3?
sudo apt-get install libcurl3?
yes sudo-apt-get install libcurl3 if you are using the terminal.
