Full Version: [AppleTV] Crystal HD *ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/
Pages: 1 2
Hello all.
I got my Crystal HD the other day and installed it and had it up and running for a few hours. After a while the video playback became choppy, so I restarted and came back to it tonight to see what was up. I updated r27056 and now I can't get the HD recognized at all.
dmesg shows this during boot:
BroadcomCrystalHD::start
allocated 18 elem
Starting BCM70012 Device
clock is moving to 175 with n 35 with vco_mg 2
CStopping BCM70012 Device
BroadcomCrystalHD: Found HW and started driver SW.
Then when I load XBMC I see this:
CInitializing Dio pool 10 1024 3058 0x1dbbf24
Firmware Downloaded Successfully
*ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/crystalhd/driver/darwin/crystalhd_hw.c:1799: Firmware command T/O
*ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/crystalhd/driver/darwin/crystalhd_hw.c:1810: FwCmd Failed.
fw cmd 73763001 failed
Closing user[0] handle
Deleting IOQs
Releasing RX Pkt pool
Released dio pool 10
This seems like a new error to me. Any ideas?
Ok, I downgraded to r27038 and now I get this:
*ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/crystalhd/driver/darwin/crystalhd_hw.c:560: Find and Fetch Did not find req
list_index:0 rx[493] Y:ffffffff UV:ffffffff Int:ffffffff YDnSz:ffffffff UVDnSz:ffffffff
*ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/crystalhd/driver/darwin/crystalhd_misc.c:615: Invalid arg!!
*ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/crystalhd/driver/darwin/crystalhd_hw.c:1336: Act-Q:PostIx:0 L0Sts:0 L1Sts:0 current L:0 tag:70029070 comp:ffffffff
list_index:1 rx[494] Y:ffffffff UV:ffffffff Int:ffffffff YDnSz:ffffffff UVDnSz:ffffffff
*ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/crystalhd/driver/darwin/crystalhd_hw.c:1336: Act-Q:PostIx:0 L0Sts:0 L1Sts:0 current L:1 tag:70029071 comp:ffffffff
*ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/crystalhd/driver/darwin/crystalhd_hw.c:592: Error on Tx-L0 ffffffff
*ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/crystalhd/driver/darwin/crystalhd_hw.c:624: Error on Tx-L1 ffffffff
Any chance this is just the SVN, or is my Crystal HD hosed?
babazoid Wrote:Hello all.
allocated 18 elem
Deleting IOQs
I've seen reports from some users with this error. The firmware download is timing out. The result seems to be a defective card.
davilla Wrote:I've seen reports from some users with this error. The firmware download is timing out. The result seems to be a defective card.
Thanks for the quick response. I am going to try another card... hopefully the seller I got this from will exchange it.
It's strange that it worked for a while when I first installed it and then just crapped out. Sad
Oh well. Hopefully the next card works. I'm dying to get this up and running.
Hi. I just got my card and it's giving me the same error Sad
When the apple tv first starts
dmesg | grep -i crystal
BroadcomCrystalHD:Confusedtart
PCI sleep prevented by BroadcomCrystalHD (5)
What doesn't "PCI sleep prevented by BroadcomCrystalHD (5)" mean?
kextstat | grep crystalhd
78 0 0x302c0000 0xb000 0xa000 com.broadcom.crystalhd.driver (0.9.26) <5 4 3 2>
After I start XMBC
If I look at the XMBC log.
bash-2.05b# grep -i crystal /Users/frontrow/Library/Logs/xbmc.log
13:20:19 T:2684407808 M: 13053952 DEBUG: SECTION:LoadDLL(libcrystalhd.dylib)
13:20:19 T:2684407808 M: 12652544 DEBUG: Loading: libcrystalhd.dylib
13:20:31 T:51705856 M: 12001280 DEBUG: GetMovieId (/mnt/Scratch/Volumes/LACIE/LACIE_Movies/Indiana Jones and the Kingdom of the Crystal Skull.mp4), query = select idMovie from movie where idFile=76
13:20:50 T:2684407808 M: 37605376 ERROR: CrystalHD: device open failed
13:20:50 T:2684407808 M: 37642240 INFO: CrystalHD: broadcom crystal hd not found
13:21:20 T:2684407808 M: 10907648 DEBUG: SECTION:UnloadDelayed(DLL: libcrystalhd.dylib)
13:21:20 T:2684407808 M: 10907648 DEBUG: Unloading: libcrystalhd.dylib
I guess need to get a new one..
kevin
Hi all,
just installed my crystal HD today. However I don't see the card in "Render method".
looking at the logs I get.
01:30:34 T:2684407808 M: 24059904   DEBUG: SECTION:LoadDLL(libcrystalhd.dylib)
01:30:34 T:2684407808 M: 24055808   DEBUG: Loading: libcrystalhd.dylib
01:30:34 T:2684407808 M: 23781376   ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
01:30:34 T:2684407808 M: 23764992   DEBUG: Dll libcrystalhd.dylib was not found in path
01:30:34 T:2684407808 M: 23764992    INFO: CrystalHD: broadcom crystal hd not found
running the latest and greatest, r27197. Did I miss something?
Thanks,
curlyjs Wrote:Hi all,
Thanks,
libcrystalhd.dylib is not found.
should be /usr/lib/libcrystalhd.dylib with correct permissions too.
I was having a similar issue... but turns out my setup was incorrect. Some of my config sets were incorrect causing the crystalhd not to load.
Perhaps others are having the same issue... Just be careful when editing your files.
05:12:23 T:2684407808 M: 50814976 DEBUG: SECTION:LoadDLL(libcrystalhd.dylib)
05:12:23 T:2684407808 M: 50819072 DEBUG: Loading: libcrystalhd.dylib
05:12:23 T:2684407808 M: 50810880 ERROR: CrystalHD: device open failed
05:12:23 T:2684407808 M: 50810880 INFO: CrystalHD: broadcom crystal hd not found
05:12:23 T:2684407808 M: 50810880 NOTICE: initialize done
Best instructions here: http://todayguesswhat.blogspot.com/2010/...le-tv.html
I'm still having the same issue. I'm pretty sure the rc.local loaded and the kext load and detected. Did you get the firmware issue initially?I'm trying to do final testing before returning it.
coolspot18 Wrote:I was having a similar issue... but turns out my setup was incorrect. Some of my config sets were incorrect causing the crystalhd not to load.
coolspot18 Wrote:Best instructions here: http://todayguesswhat.blogspot.com/2010/...le-tv.html
Re-did the instructions given and everything is working like a charm.
Thanks for the great work... and the support.
For the firmware timeout issue I was having as the few people in this post have had. I finally got my replacement card from Logic Supply.
Well, good news right after I put the new card in and turned it on it came right to life with no issues at all. So far it does in fact seem that replacing the card with a new one (from Logic Supply not ebay this time) fixes firmware issue. Just letting everybody else with this problem know. Smile
If someone in the US is willing to part with one of these troublesome cards that are having problems downloading firmware, I'd be interested in taking a peek at it and try and see why they are failing. No promises as to a fix as the card might just be defective. PM me and I'll send mailing info.
Just got my card in the mail and after installing it I appear to be having the exact same problem that this thread describes. I understand that it may just be defective card but if it is of any help let me know and I'll mail it to you.
Some details of what I did if it helps any follow.
This is after installing the drivers and rebooting.
-bash-2.05b$ sudo dmesg | grep -i crystal
Password:
Everything appears to be in order.
Start up XBMC and no Broadcom device listed.
-bash-2.05b$ grep -i crystal /Users/frontrow/Library/Logs/xbmc.log
21:19:56 T:2684407808 M: 15474688 DEBUG: SECTION:LoadDLL(libcrystalhd.dylib)
21:19:56 T:2684407808 M: 15450112 DEBUG: Loading: libcrystalhd.dylib
21:20:20 T:2684407808 M: 43876352 ERROR: CrystalHD: device open failed
21:20:20 T:2684407808 M: 43806720 INFO: CrystalHD: broadcom crystal hd not found
And....
bash-2.05b# dmesg | grep -i crystal
tjpeters Wrote:Just got my card in the mail and after installing it I appear to be having the exact same problem that this thread describes. I understand that it may just be defective card but if it is of any help let me know and I'll mail it to you.
The dreaded ;
Quote:ERR*:/Users/davilla/Documents/crystalhd-for-osx/trunk/crystalhd/driver/darwin/crystalhd_hw.c:1799: Firmware command T/O
message.
A user is already sending me a card that does this, then I can see if there is a real driver/lib issue or if the card is borked.
I got this error at first:
Then I re-ran through the instructions again here:
I didn't notice anything that I'd missed, but I rebooted and tried again anyway, and after that the card worked!
Fingers crossed it stays that way Smile
Pages: 1 2
