I don't follow. Where do you have { "type": "shuffle/repeat" } from?
Sorry. That was my logging. I'm not getting any notification on shuffle or repeat which is why I confused the message.
Tuesday, October 16th 2012:
Commits:
504e9c41f6720ed6edfc
- added support to control PVR streams to Player namespace
- added "channelid" property to Player.Open's "item" parameter
- added channel-specific properties to Player.GetItem (valid properties for a PVR stream/channel returned by Player.GetItem are "channeltype", "hidden", "locked", "channel", "lastplayed", "channelnumber", "rating", "title", "plotoutline", "plot", "genre", "starttime", "endtime", "runtime", "firstaired")
- added Player.OnPlay and Player.OnStop notifications when switching a PVR channel
- added new PVR namespace with the following methods
- GetProperties with properties "available", "recording", "scanning"
- GetChannelGroups
- GetChannelGroupDetails
- GetChannels
- GetChannelDetails
- Record
- Scan
Remember this is just very basic support to be able to control PVR channels i.e. list groups/channels, start a channel and control its playback. Anything else is most likely out of scope for Frodo because we are already in feature freeze so please hold your horses on any (wild) feature requests. I'll open an extra thread for feature suggestions on PVR for Frodo+1.
Great
Is there thumb support also for channels ? in getItem ?
Ah yeah "thumbnail" should give you the icon or whatever is available. Forgot to mention it in the list.
Yeah, you get the channel logo if it shows in the GUI of course
Thanks for getting this in.
Has anyone tried accessing the EPG via videodb:// or similar?
I haven't found a VFS URL that maps to EPG entries so most likely not possible right now.
It was a long shot
I think it's fair enough to expect the backend to have the EPG available anyway.
What is the correct way to navigate the PVR OSD with JSON-RPC commands?
For example, I send this command to bring up the OSD Channels window (which works correctly):
{"jsonrpc":"2.0","id": 1,"method":"GUI.ActivateWindow", "params": {"window":"pvrosdchannels"}, "id": "1"}}
Then, I try to navigate the list with:
{"jsonrpc":"2.0","method":"Input.Up","id":1}
Or with:
{"jsonrpc":"2.0","id": 1,"method":"Input.ExecuteAction", "params": {"action": "up"}, "id": "1"}
Neither works…
I'm using the latest Frodo nightly from today.
(2012-10-19, 18:30)Ayla Wrote: [ -> ]What is the correct way to navigate the PVR OSD with JSON-RPC commands?
Or with:
Neither works…
After seeing that GUI.ActivateWindow was added I've updated to the latest as well.
I can't seem to navigate to Movies from TV Shows and vice versa. whenever I send the following command I get sent to the one I was previously at:
{"jsonrpc":"2.0","id": 1,"method":"GUI.ActivateWindow", "params": {"window":"video"}, "id": "1"}}
Is there a way to go directly to Movies or TV Shows?
Or with:
Neither works…
Will have to give this a try.
(2012-10-19, 22:52)Jasp Wrote: [ -> ]After seeing that GUI.ActivateWindow was added I've updated to the latest as well.
You can pass a specific node in the "parameters" parameter which will be passed on to the activated window and open that node. If you e.g. want to go directly to the list of movie titles you need to do
{ "jsonrpc": "2.0", "method": "GUI.ActivateWindow", "params": { "window": "video", "parameters": [ "MovieTitles" ] }, "id": 1 }
For the list of TVShow titles you replace "MovieTitles" with "TvShowTitles".
Or with:
Neither works…
I just tested this and it works for me. But there are two things that might cause this problem:
- Calling GUI.ActivateWindow with a "window" parameter that is actually a dialog will block that request/thread until the dialog has been closed.
- There can be a dead lock when switching channels etc so maybe your XBMC was already dead locked when you tried those commands.
(2012-10-21, 10:57)Montellese Wrote: [ -> ] (2012-10-19, 18:30)Ayla Wrote: [ -> ]What is the correct way to navigate the PVR OSD with JSON-RPC commands?
Or with:
Neither works…
I just tested this and it works for me. But there are two things that might cause this problem:- Calling GUI.ActivateWindow with a "window" parameter that is actually a dialog will block that request/thread until the dialog has been closed.
Thanks for the help!
The first point sounds like that could be the problem, how can I avoid that, can I call the "pvrosdchannels" dialog/window with another command?
I'm still trying to figure out this JSON-RPC stuff, I don't quite understand the command-structure/what each element in a command means
