Running the 20130104-de8789a nightly. The case sensitivity issue of playing blu-ray ISO's is fixed. Thank you.
I have another issue, and I am not sure if this is how it is supposed to be or a bug. Now when I play a blu-ray ISO file using Player.Open, my calls to Player.GetItem return no/blank info. If I play the same file via the GUI the GetItem info is populated. The file is in the library. Is this the same thing Tolriq and others are reporting above? I do see the label, no other info though...
[Player.Open Example
SendTCP: Sending (153 Bytes) - {"id":31,"jsonrpc":"2.0","method":"Player.Open","params":{"item":{"file":"smb://AV-NAS/media/Movies/The Amazing Spider-Man/The Amazing Spider-Man.ISO"}}}
GetResp: Response (96 Bytes) - {"jsonrpc":"2.0","method":"Playlist.OnClear","params":{"data":{"playlistid":1},"sender":"xbmc"}}
GetResp: Response (39 Bytes) - {"id":31,"jsonrpc":"2.0","result":"OK"}
SendTCP: Sending (194 Bytes) - {"id":51,"jsonrpc":"2.0","method":"Player.GetItem","params":{"playerid":1,"properties":["cast","plot","year","mpaa","showtitle","title","season","episode","thumbnail","fanart","streamdetails"]}}
GetResp: Response (270 Bytes) - {"id":51,"jsonrpc":"2.0","result":{"item":{"cast":[],"episode":-1,"fanart":"","label":"The Amazing Spider-Man.ISO","mpaa":"","plot":"","season":-1,"showtitle":"","streamdetails":{"audio":[],"subtitle":[],"video":[]},"thumbnail":"","title":"","type":"unknown","year":0}}}
Played Through GUI Example
SendTCP: Sending (195 Bytes) - {"id":143,"jsonrpc":"2.0","method":"Player.GetItem","params":{"playerid":1,"properties":["cast","plot","year","mpaa","showtitle","title","season","episode","thumbnail","fanart","streamdetails"]}}
GetResp: Response (14799 Bytes) - {"id":143,"jsonrpc":"2.0","result":{"item":{"cast":[{"name":"Andrew Garfield","role":"Spider-Man / Peter Parker","thumbnail":"image://http%3a%2f%2ffiles.mymovies.dk%2fPhotos%2fd6b13260-cfa6-4fa6-9eb9-a9121a48a746.jpg/"},{"name":"Emma Stone","role":"Gwen...
19:49:05 T:7968 DEBUG: JSONRPC: Incoming request: {"id":210,"jsonrpc":"2.0","method":"Player.GetItem","params":{"playerid":1,"properties":["cast","plot","year","mpaa","showtitle","title","season","episode","thumbnail","fanart","streamdetails"]}}
19:49:05 T:7968 DEBUG: JSONRPC: Calling player.getitem
19:49:05 T:7968 DEBUG: CVideoDatabase::GetMovieId (), query = select idMovie from movie join files on files.idFile=movie.idFile where files.idPath=78
