That's it! Thanks Milhouse. Here's the full blob in case others in search of streamsilence docs find this post:
"control":{
"type":"list",
"multiselect":false,
"delayed":false,
"format":"string"
"help":"Select the behaviour when no sound is required for either playback or GUI sounds.[CR][Always] Continuous inaudible signal is output, this keeps the receiving audio device alive for any new sounds, however this might also block sound from other applications.[CR][1-10 Minutes] Same as [Always] except that after the selected period of time audio enters a suspended state.[CR][Off] Audio output enters a suspended state. Note: Sounds can be missed if audio enters suspended state.",
"parent":"",
"level":"standard",
"default":1,
"enabled":true,
"value":1,
"label":"Keep audio device alive",
"options":{"value": -1, "label": "Always"}, {"value": 0, "label": "Off"}, {"value": 1, "label": "1 Minute"}, {"value": 2, "label": "2 Minutes"}, {"value": 3, "label": "3 Minutes"}, {"value": 4, "label": "4 Minutes"}, {"value": 5, "label": "5 Minutes"}, {"value": 6, "label": "6 Minutes"}, {"value": 7, "label": "7 Minutes"}, {"value": 8, "label": "8 Minutes"}, {"value": 9, "label": "9 Minutes"}, {"value": 10, "label": "10 Minutes"},
"type":"integer",
"id":"audiooutput.streamsilence"
