This is really frustrating, I can no longer play mp4 files on my Apple TV... I am not 100% sure when it started but I know these files used to play, I created them a long time ago with Visualhub (mostly) and I have watched them several times. Now I just get either an error "failed to play" or nothing at all.
I turned on debugging and did a pastebin *the file I tried playing now is "Forgetting Sarah Marshall.mp4"
http://pastebin.com/m80393ea
I would really really appreciate if anyone saw something I could do to fix this rather than re-encoding all my files
THANKS!!
zerostar Wrote:This is really frustrating, I can no longer play mp4 files on my Apple TV... I am not 100% sure when it started but I know these files used to play, I created them a long time ago with Visualhub (mostly) and I have watched them several times. Now I just get either an error "failed to play" or nothing at all.
THANKS!!
Bet you installed NitoTV and also picked the quicktime for Perian which will break mp4 playback. Google for how to revert this.
I have Nito Tv and Perian and it plays mp4 just fine
To revert you can try to ssh into the atv and issue those commands
sudo mount -uw /
sudo rm -rf /Library/QuickTime/Perian.component
sudo rm -rf /Library/QuickTime/AC3MovieImport.component
sudo rm -rf /Library/Audio/Plug-Ins/Components/A52Codec.component
sudo mv /System/Library/QuickTime (disabled)/QuickTimeH264.component /System/Library/QuickTime
sudo mount -ur /
sudo reboot
Now you should be back at the apple H264
I never installed anything besides Launcher and XBMC. Unless I did so back before patchstick was around, but I know I've played mp4's since all that
Also, it does play Some mp4's just not all. I went thru all and there were 14 out of about 30 that would not play. Running them thru Roadmovie with just the "flatten" setting gives me a .mov and those play. Was able to do them all last night but I saved the mp4's also.
Can I still remove (or try to) the Quicktime plugins/components just incase that is interfering? I'll check and see if they are installed when I get back home.
Once removed you are back where you were and can eventually reinstall with Nito
I only use XBMC, so removing all those won't hurt XBMC or the Standard AppleTV [frontrow] player right?
You hurted it already as things dont work !!!
LOL true. Actually I think those mp4's got messed up somehow... Several new ones (720p) are working just fine today, as well as many old ones.
Yep I had none of those files... so I guess it was just my mp4's screwed up somehow :\
