Full Version: [LIVE] XBMC Live boots to command line?
SOLVED: Had to manually install newest nvidia driver from the nvidia site, 190.53. No others would work.
I have an ASRock ION330 which was running Camelot RC1 perfectly from HDD. I updated to the final before the repack and it would boot to the command line prompting "login as:"
I then updated once the repack came out and same prob. As it was Christmas Day here I left it and went away on holidays. Now I am back and have updated to the newest SVN, 27017 I think. However it still loads up to the command prompt and XBMC gui doesnt load.
If i do a fresh install from CD will I lose all the media I have on the drive?
Please help
Cheers
EDIT:
I have tried "startx" now and get the following:
X.Org X Server 1.6.4
Release Date: 2009-9-27
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-23-server i686 Ubuntu
Current Operating System: Linux XBMCLive 2.6.31-16-generic #53-Ubuntu SMP Tue Dec 8 04:01:29 UTC 2009 i686
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.31-16-generic root=UUID=1a8f759e-3bbf-47f4-81f1-8a7b57d9b0cd ro quiet splash xbmc=autostart,nodiskmount,setvolume loglevel=0
Build Date: 14 November 2009 05:48:26PM
xorg-server 2:1.6.4-2ubuntu4.1 (buildd@)
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan 24 08:25:02 2010
(==) Using config file: "/etc/X11/xorg.conf"
dlopen: /usr/lib/xorg/modules/extensions//libglx.so: undefined symbol: _nv000028gl
(EE) Failed to load /usr/lib/xorg/modules/extensions//libglx.so
(EE) Failed to load module "glx" (loader failed, 7)
FATAL: Module nvidia not found.
(EE) NVIDIA: Failed to load the NVIDIA kernel module. Please check your
(EE) NVIDIA: system's kernel log for additional error messages.
(EE) Failed to load module "nvidia" (module-specific error, 0)
(EE) No drivers available.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
ddxSigGiveUp: Closing log
giving up.
xinit: No such file or directory (errno 2): unable to connect to X server
xinit: No such process (errno 3): Server error.
I have updated the nvidia driver to a number of diff ones from 185 to 190 with no change.
