I have what i consider to be a large library, and navigating through a long list of artists it kind of a pain. Is there some way to group library by their first letter?
For example, suppose I clicked on "Artists" in my library to view all artists. Instead of seeing a loooong list of my artists and having to page down a gazillion times, I'd like to see:
A-B
C-D
E-F
... (etc)
Y-Z
That way I would only see 12 items (ok maybe 13 if I somehow included artists that started with numbers/symbols) and could quickly navigate to a particular artists.
Any thoughts on this, is there another approach I should be considering?
Ok- I'm a bit of a newb on this board... can't seem to edit my title of the post though I tried a couple of times it doesn't "stick"...
"Grouping of" instead of "Gouping or".
Also, not sure how I ended up posting to this forum,
perhaps an op could move this post to "General Help and Support"?
If not I'll post there in a couple of days if I don't get a reply here.
Thanks...
Gamester moved your post to FR.
We already support this, albeit not in the manner you require exactly.
1. Use SHIFT-<letter> to jump through the list if you have a keyboard plugged in.
2. Use the JumpSMS2 - JumpSMS9 with a remote control to SMS input down to the letter you want.
3. Use NextLetter/PrevLetter actions in your keymap to jump to the next and previous letter.
Cheers,
Jonathan
Thank you for the help Jonothan (and Gamester!)
I will experiment a little. Maybe I can use 0-9 on my remote and map them to letters.
Thanks again...
digidigi Wrote:Thank you for the help Jonothan (and Gamester!)
Thanks again...
Do a search for JumpSMS - its exactly what you are looking for. You would press 6 on remote to go directly to artists beginning with M etc etc
Works great!
I was a little skeptical at first as I am not much of a dial-pad texter, but the letters are on the number keys of my remote, so its really quite easy.
Was just talking in IRC about this with someone who asked for a similar feature. I was looking for this function too.
SMS function is an OK solution but requires many more keypresses and isn't as intuitive. Shift + Letter function is useless to anyone who uses a normal remote.
Something like this in xbmc would be awesome.
I looked it up on google and the code seems very simple. Something like this maybe?
select substr(artist_name,1,1) as alpha, count(id)
from music
group by substr(artist_name,1,1)
This would be great for movies and music browsing
